When I download these programs (the latest versions of both), I usually just extract them to any old location (C:\WINDOWS\Start Menu\Programs\) and their respective folders. That means, when it comes time to uninstall them, I have to manually delete the files instead of uninstalling them in Control Panel: Add/Remove Programs. Does anyone know how to fully install them so I can simply remove them in Add/Remove Programs?
Thanks.
But why would you want this???
BTW No installer means no de-installation in Add/Remove programs. These are just some registry settings how to uninstall the program.
In fact this is better the installed program's are just in the directory you put them in. And removing them completely removes the program.
Is this the correct way to install ffdshow just for VirtualDub?
By tigerb in forum Newbie / General discussionsReplies: 8Last Post: 25th Nov 2013, 01:23 -
Could running both Super and Virtualdub have borked my Windows install?
By brassplyer in forum Newbie / General discussionsReplies: 8Last Post: 15th Jan 2011, 06:55 -
VobSub/VirtualDub Install Problem
By locoblacbelt in forum SubtitleReplies: 0Last Post: 18th Jul 2008, 11:35 -
Windows Color Profiles ignored by TMPGenc, VirtualDub, etc. ?
By sanlyn in forum Video ConversionReplies: 13Last Post: 28th Jun 2008, 09:42 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 13:43
