Hello everyone and thanks for reading this.
I try almost everything here : https://forum.videohelp.com/threads/372157-New-upscaling-algorithm-waifu2x
When I try to using it(with MeGUI), I have this error message:
My script:
Code:LoadPlugin("C:\Users\Hokuto\Desktop\Encodage\MeGUI_2507_x86\tools\avisynth_plugin\SmoothD2.dll") LoadPlugin("C:\Users\Hokuto\Desktop\Encodage\MeGUI_2507_x86\tools\avisynth_plugin\Waifu2xAvisynth.dll") LoadPlugin("C:\Users\Hokuto\Desktop\Encodage\MeGUI_2507_x86\tools\ffms\ffms2.dll") FFVideoSource("G:\***.mp4", fpsnum=121, fpsden=5, threads=1) SmoothD2(quant=1, num_shift=4, Matrix=18, Qtype=2, ZW=5) Waifu2x(nr=1, scale=2)
I don't mind waiting 6-7h for a video (or more), but I want to make this Waifu2x works.
Thanks in advance for your help.
Results 1 to 11 of 11
I have the same message event without SmoothD2 in my script.
I'll try to convert to YV12/24.
Thanks for your answers, both of you.
Sorry to bother you again but I have a problem.
When I try to use "ConvertToYV12()" the problem stay the same. But when I try to use "ConvertToYV24()", I have a white preview and the programme crash after I close the preview.
Thanks again for your help. -
What's the frame size of the video you're trying to upscale? In my experience it doesn't work with source frames much over 720x480. I think it runs out of memory but doesn't report the problem, just fails with unpredictable behavior.
I try to upscale one 720p to 1080p.
Using Waifu2x-koroshell is way too long frame by frame. ^^' -
You won't be able to upscale 720p to 1080p with 32 bit waifu2x for AviSynth. And even if you could it would take more than a minute per frame, over 500 hours for a 22 minute video. You'll be much better off using nnedi3_rpow2() with a little sharpening. It's almost as good but much faster.
The vapoursynth Waifu2x-w2xc version is pretty stable and fast ("fast" compared to the avisynth version), but there is a learning curve to vapoursynth (steeper curve than avisynth IMO). But this version can use cpu/gpu
Thanks for all your help, but i will abandon this upscale project with waifu. Thanks again.
I can replicate your error message in the 1st post (with sourcefilter + waifu2x only) . For some reason, even if you send YV12 source, it still sends that message (you can check with info() ) . But it only occurs with certain source filters like ffms2, lsmash. For some reason directshowsource() works, even if all the characteristics in info() were matched between lsmash, ffms2. I can't explain it.
Another option you can try is the aviutl version
The vapoursynth version is about 30-40x faster than the avisynth version . The avs version has no optimizations yet.
How to upscale a video using waifu2x?
By claublog in forum Newbie / General discussionsReplies: 6Last Post: 26th Mar 2017, 11:16 -
problem after problem converting Ts and MKV to mp4
By xtal_01 in forum Video ConversionReplies: 4Last Post: 3rd Oct 2016, 20:52 -
How To Upscale a Video Using waifu2x-caffe?
By Sternritter in forum Video ConversionReplies: 4Last Post: 28th Aug 2016, 12:06 -
New upscaling algorithm: waifu2x
By MaverickTse in forum Latest Video NewsReplies: 44Last Post: 15th Dec 2015, 08:49 -
AVI to MP4 H.264 buffering problem (not MOOV problem)
By Qexpres in forum Video Streaming DownloadingReplies: 13Last Post: 12th Dec 2012, 07:33
