I'm using AVISynth and I only just discovered that there was an "Average" option for the YV12 ColorMatrix setting. I love the way the color turns out while using it. The problem is, when using it on an HD MP4 file, I get massive slowdown.
Is there a way to fix this at all? The temporary solution is just downsizing it to 640 or 720. I understand if this filter just can't handle HD video at all.
AnonymousGuest
If smike means to say ConvertToYV12(matrix="average")...
There's normally no speed difference between color matrices, but looking into the source code,
I was a little surprised to see that calling ConvertToYV12 with no arguments invokes a faster routine:...so any matrix argument will slow down the conversion, not only "average."Code:http://avisynth2.cvs.sourceforge.net/viewvc/avisynth2/avisynth/src/convert/convert.cpp...ew=markup#l307 AVSValue __cdecl ConvertToYV12::Create(AVSValue args, void*, IScriptEnvironment* env) { PClip clip = args[0].AsClip(); const VideoInfo& vi = clip->GetVideoInfo(); if (vi.IsYUY2() && !args[3].Defined() && !args[4].Defined() && !args[5].Defined()) // User has not requested options, do it fast! return new ConvertToYV12(clip,args[1].AsBool(false),env); return ConvertToPlanarGeneric::CreateYV12(args,0,env); }
But not by very much, or someone would have complained before now eh?
I haven't noticed a "massive slowdown."Last edited by raffriff42; 11th Nov 2016 at 07:29. Reason: 'looking into the source code'
AnonymousGuest
Did some testing with AVSMeter:
Script:
"ConvertToYV12" without any args:Code:colorbars(width = 1920, height = 1080, pixel_type = "rgb32").killaudio().assumefps(25, 1).trim(0, 1999) #converttoyv12() #or #converttoyv12(matrix = "average")
ConvertToYV12(matrix = "average"):Code:[Runtime info] Frames processed: 2000 (0 - 1999) FPS (min | max | average): 122.2 | 128.0 | 127.2 Memory usage (phys | virt): 402 | 400 MiB Thread count: 1 CPU usage (average): 25%
Using different source colour spaces also did not reveal any difference in speed.Code:[Runtime info] Frames processed: 2000 (0 - 1999) FPS (min | max | average): 122.3 | 128.0 | 127.3 Memory usage (phys | virt): 402 | 400 MiB Thread count: 1 CPU usage (average): 25%
My mistake, It's "ConvertToYV12" Matrix. Going back through my script, the slowdown comes from using that, in conbination with a ConvertToRGB Matrix setting.
Like I said, I like the picture it produces, but I don't think that those two options together can handle an HD MP4.
Script
LoadPlugin("C:\Users\#####\Documents\#####\ffms2.d ll")
Import("C:\Program Files (x86)\AviSynth\plugins\FFMS2.avsi")
AudioDub(FFAudioSource("TOSP.mp4"),FFVideoSource(" TOSP.mp4",threads=1))
#SincResize(640,480)
ConvertToRGB(matrix="PC.709")
ConvertToYV12(matrix="AVERAGE")
MediaInfo
General
Complete name TOSP.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 818 MiB
Duration : 24mn 15s
Overall bit rate : 4 716 Kbps
Encoded date : UTC 2016-08-03 08:59:18
Tagged date : UTC 2016-08-03 08:59:26
©TIM : 00:07:20:15
©TSC : 25
©TSZ : 1
Video
Format : AVC
Format profile : Main@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : avc1
Duration : 24mn 15s
Bit rate : 4 372 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.084
Stream size : 759 MiB (93%)
Language : English
Tagged date : UTC 2016-08-03 08:59:18
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 24mn 15s
Source duration : 24mn 15s
Bit rate mode : Variable
Bit rate : 317 Kbps
Maximum bit rate : 420 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : 40ms
Stream size : 55.1 MiB (7%)
Source stream size : 55.1 MiB (7%)
Language : English
Tagged date : UTC 2016-08-03 08:59:18 -
Maybe it makes only a tiny bit of difference here but, for fastest results you're supposed to list the video first when using AudioDub.
Unless you need the audio, try running your script without it:
And it seems silly to me to use ColorMatrix just because you 'like the picture it produces'.
MP4 to see on pc have to be colormatrix 601?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 25th Mar 2015, 21:15 -
avisynth: how to apply colormatrix to vid=FFVideoSource?
By marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 25th Mar 2015, 11:04 -
Colormatrix Question
By tebugg in forum Authoring (DVD)Replies: 3Last Post: 9th Oct 2014, 19:42 -
how to change colormatrix in MEncoder?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 2nd Nov 2013, 15:00 -
setting the correct colormatrix in x264
By codemaster in forum Video ConversionReplies: 1Last Post: 2nd Mar 2012, 23:14
