  1. Can it convert analog signals to digital? From the attached pic, can you connect analog cables to the front and from the back, connect an SDI cable to your capture card?
    Aug 2006
    No, it isn't a digital to analog converter. It is an accessory available for specific AJA KONA cards which makes it easier to connect other devices to them. The multi-pin connection on the back of the breakout box is for analog. It is connected to the analog connector on the card with a cable made for that purpose. This is what KONA says:
    Breakout Boxes
    All KONA cards feature an optional Breakout Box with supplied cables that enable extended I/O and the ability to easily connect to KONA without having to access the rear of the computer tower.
