Hi Friends,
I want to write an mp4 file, its size is 3.33Gb. I want to cut this file in 1GB each for write a DVD.
How I split this file in 1GB each? Which software is used? Plz help me......
To expand upon what hech54 said,
"DVD" playback could mean authored or data-file forms.
If authored, you'll need to convert from MP4 to authoring-compliant MPEG2 intermediate source files (at DVD-appropriate bitrate limits) - along with audio - as well as author, to arrive at your VIDEO_TS VOBs. Likely, you'll have to use the encoder to create segmented encodes so each MPEG authoring SOURCE is well within disc capacity limits. Then the compiling of the authored title will automatically do the 1GB VOB splits for you. Doing it manually is certain to fail.
If data-file, you just need to drop it on the disc (in the root or some subfolder) and burn (assuming the file is ALREADY compliant with the intended players' specs).
Which one you use depends on which player(s) you expect to use...
split a video every 60 minutes
By RBCC in forum EditingReplies: 8Last Post: 26th Sep 2015, 15:25 -
Writing / Drawing on video.
By racer-x in forum EditingReplies: 4Last Post: 15th Jul 2015, 15:27 -
Video to Video not writing to external drive
By karenlorr in forum DVD RippingReplies: 19Last Post: 1st May 2013, 11:42 -
Video split
By Videographer in forum EditingReplies: 1Last Post: 6th Feb 2012, 11:31 -
How to Split Video/Pictures as seen on TV
By HoosierGuy in forum EditingReplies: 13Last Post: 19th Dec 2011, 15:49
