  1. Hi guys pretty new to this. How would I go about burning a blu Ray image onto a bd-r 25gb when the img is about 37gb. Obviously I want to retain the hd format of 1080p and the hd audio but is there a way to get this down to under 25gb ? I really don't want to fork out for some dl discs they are so much more money considering they are only twice the size.
    Would I need to make a lossless mkv of the img and then take aspects out like unwanted audio tracks? How can this be done. Specifically this is a fan preservation of star wars by team negative one. They're most recent version is 37gb but previous ones have always been small enough to just burn the img straight onto a bd.
    Any advise would be great. From what I've read would make mkv or handbreak do the job?
  2. Originally Posted by videobruger View Post
    Advising a newbie to use Rebuilder is like sending someone to college before going to high school.
    Sep 2011
    BDRebuilder, I have been using it for years and find it easy to use.
  4. Originally Posted by tarzan54 View Post
    Thanks but it seems like a lot of steps to do this . Would something like Leawo or blue copy diamond do the job but in one program?
    Nov 2003
    West Texas
    BD Rebuilder is one program. Everything it uses, it accesses automatically. All you have to do is install the helper programs once and it does the rest.
    These days all you need to install is AviSynth and the LAV Filters. Use the ones from this page: http://forum.doom9.org/showthread.php?t=143716
    If you need a guide, this one at MyCE is still useful: http://club.myce.com/f32/bd-rebuilder-guide-313227/
  6. Originally Posted by Kerry56 View Post
    Thanks you have been so helpful
