Results 1 to 11 of 11
  1. I'm in trouble with this mov (from my camcorder)
    It's AVC / lpcm FHD 59.94 fps interlaced
    I tried to demux it with mediacoder, i tried videoredo (almost ok except it gives me a 25fps file... huh??)
    Or an alternative solution would be a good source filter for avisynth (forget directshow i need frame accuracy)
  2. Try L-Smash Work's lsmashvideosource() or lwlibavvideosource() (and respective ...audio...() ) for AviSynth.
    Just extraction: mp4box -raw 1 "input.mov" (for first track).
  3. Can you upload here the L-SMASH-Works.zip? it don't work on the wiki
  4. Thanks but when i unzip the zip the folder are empty !
    Upload the zip on mega or somewhere else please
  5. Your extracting program might be obsolete. Use recent 7zip or WinRAR.
    http://www.7-zip.org/
  6. nope it's working fine. This dropbox thing is killing me...Please up it somewhere else when you have some time.
  7. is it the zip you use on your computer or is it the one taken from dropbox then reuploaded ?
    because it's empty..still.
    I have plenty of compressed archives (rar etc..) on my comp' winrar works just fine i can tell you that.
  8. Originally Posted by themaster1 View Post
    Like I told you: your extraction program is obsolete.
    I have plenty of compressed archived (rar etc..) on my comp' winrar works just fine i can tell you that.
    Not all files are created equal... LZMA2 needs at least WinRAR 3.91.
  9. Finally thank you, now i see something
