Hi,
I have a video which i got from YouTube, and I'm trying to crop the video and export to a .mp4 file, and the source video is over 2 hours long.
In the past I've tried using FCP 7 Compressor, and overnight I've tried MPEG Streamclip but it took 8 hours to convert 67% of the video. I know I must be doing something wrong!
I'm open for any suggestions as I feel like all I need to do is change a few settings and it should be a lot quicker. I am using a mid-2015 MBP, 2.5GHz, i7, 16GB RAM
Here are the specs of the source video via VideoSpec
***** Analyzed File Results *****
*** General Parameters ***
- Container: MP4 - QuickTime
- Size: 2.545 GB
- Duration: 2h 21mn
- Bitrate: 2 397 Kbps
*** Video Track Parameters ***
- Format: H.264/MPEG-4 AVC
- Bitrate: Max.: --- / Average: 2 268 Kbps / Min.: ---
- Frame rate (fps): Max.: --- / Average: 25.000 / Min.: ---
- Encoding profile: Main@L3.1
- Image size: 1280*720
- Pixel Aspect Ratio: Undefined
- Display Aspect Ratio: 16:9
- Interlacing: Progressive
*** First Audio Track Parameters ***
- Format: AAC - MPEG-4 audio
- Bitrate: 126 Kbps
- Resolution: Undefined
- Rate: 44.1 KHz
- Channel(s): 2 (stereo)
- Position: Front: L R
Any help would be appreciated!
This really belongs in the Mac forum. I suggest you contact a mod to have the topic moved.
However, generally, source parameters are irrelevant. What is important are the target parameters. And if both source and target are not identical then conversion WILL take time. -
Did you remove letterbox bars and/or pillar bars, so that the target frame size is smaller than the source frame size? What is the output frame size?
What software did you use for this? (I didn't think MPEG Streamclip could do that.) In what format did you save the intermediate file?
2h 21mn. = 141 minutesOriginally Posted by LVee
( 141 * 60 * 25 * 0.67 ) / ( 8 * 60 * 60 ) = 141705/28800 = 4.92 frames encoded per secondOriginally Posted by LVee
I did a test clip encoding using MPEG Streamclip on my side, which I clocked at 6.56 frames encoded per second. That would be: 4.82 frames per second when compensated for the difference in chip frequency (3.4/2.5). Meaning: your encoding speed is on par with what can be expected from MPEG Streamclip’s MP4 export, imho.
There are faster encoders. I encoded the same test clip with an ffmpeg-based encoder (iFFmpeg) at 9.8 times the encoding speed of MPEG Streamclip (=QuickTime encoder). (Compare 49 minutes to 8 hours, or 01:13:10 to 11:56:26!)Originally Posted by LVee
Extracting subtitles from mp4 video on youtube
By TatsuSheva in forum SubtitleReplies: 4Last Post: 28th Aug 2016, 16:03 -
Tool for Cropping Mp4 Videos with Advanced Video Codec (AVC)
By Videopaul in forum EditingReplies: 8Last Post: 7th Jul 2016, 12:59 -
Youtube/MP4 deletes segments of video
By Headless97 in forum Newbie / General discussionsReplies: 6Last Post: 14th Nov 2012, 01:19 -
Youtube audio keeps playing after video is finished - what's going on?
By brassplyer in forum Video Streaming DownloadingReplies: 1Last Post: 30th Oct 2012, 04:54 -
Youtube MP4 double image video
By leandro in forum Video ConversionReplies: 5Last Post: 15th Aug 2012, 16:40
