I want to capture a 640x480 VGA signal, and to do so I drew from my parts box: A Pinnacle Dazzle and an unbranded VGA to S-video/composite adapter.
Now the fun starts. I lost the CD that came with the Dazzle and Pinnacle basically told me to go **** myself because my product is no longer supported.
So I installed the driver and downloaded NCH Debut Video Capture Software.
I tested this setup with the composite output of a Raspberry Pi, and the Dazzle works fine.
Now the VGA part. When I connect the adapter via composite to my laptop it does not even detect it.
When I connect the S-video cable to the Dazzle, Windows 10 sees a new monitor with 1366x768 as the only option (greyed out).
However, running Debut shows a blue screen no matter which options I try.
Okay, actually selecting PAL produces a black screen instead.
Any idea what to try?
There are various topics on here about these adapters. Some are better than others. Some are for specific tasks like connecting a laptop to a tv.
If the vga output you are trying to capture from is not pinned for composite/s-video, a simple adapter is never going to work. To discount the Pinnacle I would connect the adapter from the vga direct to a tv composite. If you still do not see the output then you need a bespoke cable/adapter which converts the signal and requires its own power.
Pinnacle/Dazzle Capture/Burning Problems
By kwood in forum Newbie / General discussionsReplies: 8Last Post: 21st Mar 2018, 08:58 -
Captures too bright (etc.) with Dazzle DVC100/Pinnacle Studio 17
By Psymon23 in forum Capturing and VCRReplies: 11Last Post: 13th Mar 2016, 07:01 -
Pinnacle Dazzle DVD Recorder DVC 101 alternative software
By Cazz in forum Capturing and VCRReplies: 4Last Post: 1st Jul 2014, 21:26 -
Problems with Dazzle Video Creator Platinum HD / Pinnacle Studio 15
By ElectrOStudios in forum Capturing and VCRReplies: 0Last Post: 14th Aug 2013, 22:14 -
VGA to Capture Card
By kindejj in forum Capturing and VCRReplies: 10Last Post: 27th Aug 2012, 08:46
