No replies, but I was successful with this to shrink mkv from 33.1 GB to 8.3GB with about the same quality.
1. MKVCleaver x64 to strip out only Stream 0 Video and Stream 1 Audio.
2. MKVToolNix to remux to mkv.
3. PopCorn MKV AudioConverter to re-encode dts to AC3
4. RipBot to re-encode to mkv only changing to 2-pass and lock size 8150.
Was quite simple and I really like the results.
Did you know MKVMergeGui can do all of this except the changing DTS to AC3, But then PopCorn MKV AudioConverter can do that part.
So load the original file into MKVMergeGui and untick any tracks you don't want, then remux. Next using PopCorn MKV AudioConverter and fix the audio track. DoneSONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Old thread but i have the same question as OP and will borrow this thread instead of starting a new one. I also have large MKV files that i need to shrink. These MKVs are 1:1 rips from discs made with MakeMKV.
I would like to keep the lossless audio tracks from the remux and shrink the video with about 50% of the bitrate.
Can this all be done with RipBot264 or do i need other software?
How should i setup Ripbot if i want to keep the lossless audio and only encode the video?
Is there any up to date guide showing these settings?
Thanks in advance.
Edit: Nevermind, figured it out myself.Last edited by rocknrolla115; 24th Mar 2018 at 16:28.
problem: importing Mkv blu-ray in ripbot
By vivabarca in forum Blu-ray RippingReplies: 2Last Post: 6th Dec 2014, 13:42 -
shrink mkv with handbrake
By hilario in forum Video ConversionReplies: 10Last Post: 23rd Mar 2013, 11:12 -
How to shrink an MKV while retaining HD audio
By lordhutt in forum Newbie / General discussionsReplies: 9Last Post: 19th Aug 2012, 08:58 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
RipBot Problem - avi to mkv
By SmokerBamboo in forum Video ConversionReplies: 13Last Post: 2nd Apr 2012, 19:56
