    Feb 2016
    Thailand
    Hi Everyone,
    I hope you can help me with my small problem.
    I have an MKV file which has a DTS 6 channel audio soundtrack. The problem is that the sound is very low.
    Is there a method of extracting the sound file and increasing the volume?
    Many Thanks.
  2. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Probably the quickest way to do it would be to convert from DTS to AC3 using Popcorn MKV Audio Converter
    There is an option to adjust either all tracks or selectively one particular track - often the centre track that carries most dialog
    Feb 2016
    Thailand
    Many thanks for your replies. I'll give them a try.
