In 2008 I transferred my DV tapes to my PC as .avi files. The program I used split them up into 640MB files or less, so any recording over 3min 6 secs has multiple files part 2, part 3 etc. I can’t remember what program I used to transfer the files over to my PC. I am now only able to play the first part of any DV .avi file . ie the first 3mins 6secs. The remaining parts 2 , 3 and so on are not recognised as video files. The lead file plays fine and shows the correct run time, but once it reaches 3mins 6secs the file stops playing. All the other DV avi files with run times of less than 3mins 6secs play just fine in MPC-HC
I have tried a file joiner program but it did not work. Only the first section is playable and once it gets to 3min 6secs the video player stops.
These PC files are my only copies of recordings of my son. Is there any way for me to rejoin the avi files which are split and view them past 3mins 6secs ?
I would greatly appreciate any help
You could also try concatenating them manually. Open a command prompt and navigate to the folder where the files are stored. Enter the following, specifying your actual filenames.
Code:copy /b input_1.avi + input_2.avi + … + input_n.avi output.avi
How to split multiple parts with ffmpeg?
By ben45 in forum Video ConversionReplies: 4Last Post: 10th Oct 2016, 03:35 -
Split subtitle in 12 parts by the end of the video
By Username2013 in forum SubtitleReplies: 2Last Post: 14th Jan 2016, 12:29 -
Frame rate & interlacing on imported DV .avi files
By MiniDV_newb in forum Capturing and VCRReplies: 71Last Post: 21st Dec 2014, 14:28 -
Split AVI video into several parts
By phedon in forum Newbie / General discussionsReplies: 5Last Post: 27th Jan 2013, 12:18 -
[VirtualDub] How to split avi to x parts with one operation?
By ralf07 in forum Video ConversionReplies: 3Last Post: 5th Apr 2012, 18:01
