My current version of photoshop won't let me save an image to bitmap or jpeg that exceeds 30,000pixles in horizontal dimensions.
Just looking for a basic free program that will let me make an image over 30K & save it as bitmap or jpeg.
thanks
Results 1 to 11 of 11
I'm not sure if you consider it 'basic,' but it looks like The GIMP should be able to do it.
You'll need to change the "Maximum new image size" setting (under Preferences > Environment (defaults to 64MB, I think)), however. I tried creating a new image, and changing the default resolution from 640x400 to 40000x400, and it warned me the resulting image would be 149.1 MB.If cameras add ten pounds, why would people want to eat them? -
Perhaps ImageMagick or Gimp (depends on edit requirements) ?
http://www.imagemagick.org/Usage/files/#massive
https://developer.gimp.org/api/2.0/libgimpbase/libgimpbase-gimplimits.html -
https://groups.google.com/forum/#!topic/ptgui/gmBkEV_Y3ME - seem you need to change image format.
PS does support 300,000 x 300,000 , at least on newer versions . It might be limited in older versions because of RAM or x86 limitations
https://helpx.adobe.com/photoshop/using/image-size-resolution.html
I exported a 40K x 2K jpeg from PS (it gave a warning that it wouldn't be supported on older PS versions), then opened it in irfanview . Irfanview is a free lightweight image editor so it supports at least 40KPhotoshop supports a maximum pixel dimension of 300,000 by 300,000 pixels per image.
http://www.irfanview.com/ -
Photoshop CS6 (v13, 2012) first featured larger dimensions on JPEG files: The 30,000 pixel limit of previous versions was gone.
There is still the 65,535 pixel limit per JPEG specification, though. -
There are better ways to get the result you want. Has to be. Probably involving (just a guess here) tiled images.
Bert Monroy completed an amazing panoramic image back in 2010. It took him four years! Did not watch the tutorial listed below, but from other reading it sounds like he used Illustrator for the final output, which contained many, many Photoshop images.Bert Monroy: The Making of Times Square, The Techniques (lynda.com)
Take a virtual journey to the bustling streets of New York in Bert Monroy: The Making of Times Square. Digital painter Bert Monroy reveals how he created the minute details that build the impressive 108,000 x 21,600 pixels, 25-feet wide photorealistic portrait of this iconic intersection. -
VSDC video editor shows image on preview, but when I export the video
By elisape in forum Newbie / General discussionsReplies: 2Last Post: 20th Oct 2016, 04:51 -
Can you use Spline36Resize on just the width?
By VideoFanatic in forum RestorationReplies: 6Last Post: 13th Jan 2016, 11:48 -
How do you change image border color in VSDC video editor
By Cyborggeffien in forum Newbie / General discussionsReplies: 0Last Post: 1st Aug 2015, 22:11 -
Hard-Link Supported Image Editor?
By Vassile in forum EditingReplies: 2Last Post: 14th Nov 2014, 21:10 -
Win 7: How to change default image editor from MS paint to Photoshop
By Denvers Dawgs in forum ComputerReplies: 6Last Post: 4th Feb 2013, 01:11
