Hello,
I've this mpg video with mpeg-ps codec. I wonder if it's possible to convert it to something better quality video.
Here is the mediainfo output. Thanks
Code:Complete name : KSvar.mpg Format : MPEG-PS File size : 3.43 GiB Duration : 2 h 2 min Overall bit rate mode : Variable Overall bit rate : 3 992 kb/s Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@High 1440 Format settings, BVOP : Yes Format settings, Matrix : Default Format settings, GOP : Variable Duration : 2 h 2 min Bit rate mode : Variable Bit rate : 3 752 kb/s Width : 768 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate : 25.000 FPS Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.339 Time code of first frame : 00:00:00:00 Time code source : Group of pictures header GOP, Open/Closed : Open Stream size : 3.22 GiB (94%) Transfer characteristics : BT.601 Matrix coefficients : BT.601 Audio ID : 192 (0xC0) Format : MPEG Audio Format version : Version 1 Format profile : Layer 2 Duration : 2 h 2 min Bit rate mode : Constant Bit rate : 160 kb/s Channel(s) : 2 channels Sampling rate : 48.0 kHz Compression mode : Lossy Delay relative to video : -10 ms Stream size : 141 MiB (4%)
Yes, converting can only make it worse. But filtering it can fix some types of problems. What's wrong with the current video?
Thanks guys. I'm a newbie to the conversion or encoding stuff. I was wondering if the video could be changed to constant bit rate with x264/mkv format without much penalty on the quality.
Making it CBR is idiotic and won't result in higher quality. If the idea is to make it smaller, then reencode it at a lower VBR bitrate. If the idea is to somehow improve the quality with selective filtering, then we'd need a small 10-second sample, one with steady movement and that shows the problem.
768x576 progressive 3 752 kbps could be transcoded to h264 at 2000 kbps VBR without visual qualty loss. File size becomes around 2 Gbytes
Batch Convert .mpg files to .MKV with no conversion
By dvdguyjt in forum Video ConversionReplies: 1Last Post: 20th May 2015, 17:01 -
.mpg file conversion
By serious_man in forum Video ConversionReplies: 4Last Post: 4th Feb 2015, 07:10 -
Help with Audio Stream Conversion from MPG-TS
By LogoTG in forum Video ConversionReplies: 6Last Post: 24th Jan 2015, 07:22 -
Diaporama / AviSynth / conversion avi to mpg problem
By jyc in forum Video ConversionReplies: 7Last Post: 30th Aug 2013, 04:01 -
How could I do a very fast conversion from MPG skipping video frames?
By falco2000 in forum Video ConversionReplies: 21Last Post: 23rd Sep 2012, 11:44
