Does anybody know how to convert AC3 to Multichannel MPEg audio for SVCD as SVCD does support this kind of 5.1 digital surround upto 384 Kbps.
It is possible but it will waste space on your Cd, and it will play only under certain DVD player.
And you need to precess and encode the files under linux.
Try the www.doom9.com guide.
Giuliano -
Couldn`t find what I need on there to convert ac3 to mpeg multichannel, does anybody know of any programs that do this?
You are probably wasting your time and effort. The vcd standard supports only 224kbps Stereo audio. Anything outside of that is not covered under the standard. And isnt supported under most standalone players. Plus if your goal is to have 5.1 sound you need a 5.1 decoder and speakers. Anything less and you dont get the full experience, and then whats the point
Most stand alones wont play the disc and the ones that will(which will be hard to find) may be more expensive. And since the track takes up more space you will find yourself switching disc alot. -
search for my old post !
It's possible to convert ac3 to mpeg2 multichannel in windows with the use of rempeg or pub_enc.exe e besweet.
take a look to dspguru.doom9.net and search for svcd 5.1
bye
multichannel audio in MainConcept Reference
By lord25 in forum AudioReplies: 15Last Post: 2nd Apr 2009, 15:03 -
multichannel audio with multicamera setup...
By foler in forum AudioReplies: 4Last Post: 7th Nov 2008, 01:57 -
SPDIF - Why can't lossless multichannel audio be transmitted?
By ontherocks in forum AudioReplies: 15Last Post: 6th Jul 2008, 17:04 -
Rotel 7.1 MPEG Multichannel Decoder....any others?
By Disco Makberto in forum AudioReplies: 9Last Post: 30th Nov 2007, 05:23 -
multichannel audio videoconference with VLC
By grmary in forum Newbie / General discussionsReplies: 2Last Post: 16th Nov 2007, 16:24
