Hello
Am new to conversions, so please bear with me. I would also rate my computer skills as about 60% so would really appreciate if someone could lead me gently!
I recently found about a 100 plus DVDs lying in my office store and thought I would convert them into soft copy. A quick search and Google led me to Handbrake, MakeMKV and Xmedia Recode (actually I searched for "Rip and encode DVD to mkv" although I'm not sure if MKV is really the best). I first used Handbrake but for whatever reason it just refused to scan and load from my DVD drive. Next I tried MakeMKV and everything went textbook perfect! I was pleased with myself. Just that the output was 3GB plus and I preferred something between 800MB and 1.5GB.
I then tried the portable version of Xmedia Recode. The same DVD I ripped earlier gave me an output of 1.25GB. This was good, but when I played the file, I noticed that it had converted just about 50%. I tried a couple of times more with different settings and each time it was round about the 1.2GB range. Can someone guide me as to how I can do a full job and what I could have done wrong? Basically what I did was choose from profile - Samsung TV or Custom with the output as mkv. Under audio, I selected 6 channel and that was about it. When added to the queue, I can see that the output is about 2:38 hours and the encoding goes at a steady pace for 50% and then quickly finishes. If someone can create a profile for me with just that mkv and 6 channel audio with the original aspect ratio, that would be great.
Separately, I was going through a site where I download movies and noted that my favourite uploader has the following 2 settings:
AndCode:Gives an output of 800MB Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 2h 7mn Nominal bit rate : 711 Kbps Width : 720 pixels Height : 304 pixels Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : HE-AAC / LC Codec ID : A_AAC Duration : 2h 7mn Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE
Is it possible for someone to give me a profile for these two?Code:Gives an output of 1.5GB Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 2h 31mn Nominal bit rate : 876 Kbps Width : 1 280 pixels Height : 544 pixels Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : A_AAC Duration : 2h 31mn Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE
Thanks a ton![]()
I should mention if those are commercial DVDs, they are likely encrypted. Then you need a decrypter program.
I use VidCoder, a GUI for Handbrake, and IMO, easier to use, especially if you have more than one DVD drive.
I encode in batches.
I use mostly the default settings for MKV and set for AC3 audio. I also turn on 'Detelecine' and 'Decomb' to default.
But you can also use AAC for the audio if desired.
You set the quality or the output size. Most times I use 'Constant Quality' of 19 and this results in about a 2GB MKV file.
I also set 'Constant Framerate' and FPS 'Same as source'. Works well for me.
Other members may have more suggestions.
And welcome to our forums.
VidCoder for me too.
https://www.videohelp.com/software/VidCoder
Two Pass= control bitrate -
Thank you redwudz for welcoming me into the forum and for your suggestion
and thank 45remanyao for your input too
Unfortunately, with Videocoder, like Handbrake, I keep getting an error "An error occurred while scanning" with some DVDs
I'm sure that these are not encrypted as they themselves appear to be copies
Both MakeMKV and Xmedia Recode scans and get the source from all DVDs with no problem.
Anyway, I just tried Videocoder with a few more DVDs and they were all detected fine. Used the settings as suggested by the two of you (except used 20 for the quality). The process went through fine and I got an output of 1.14! More or less in the region I was looking for! Perfect!
Thank you both so much
Xmedia Recode & Variable Frame Rate
By BazzaG in forum Video ConversionReplies: 8Last Post: 15th Aug 2015, 09:52 -
Xmedia recode settings for Bluray ripping??
By davidh10_99 in forum Blu-ray RippingReplies: 6Last Post: 22nd Apr 2015, 14:31 -
XMedia Recode frame rate encoding
By 55trucker in forum Video ConversionReplies: 10Last Post: 25th Oct 2014, 21:08 -
xmedia recode
By MaxOne72 in forum Video ConversionReplies: 3Last Post: 7th Dec 2012, 12:09 -
Xmedia Recode help!
By snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2012, 11:36
