What is a good wired headworn mic? Preferably something which can be used with a typical consumer camcorder. I'm thinking a mic which requires 48V phantom power won't necessarily work with a consumer camcorder.
Thanks.
It's unusual for a headband mic to need phantom power ... most use permanently polarised capsules (electret) and only require camcorder 'plug in power'....
Quality wise they seem to fall into 3 ranges...PULSE offer a range around $50 ...the RODE HS2 is around $300 - and the 'pro' DPA 4088 will set you back around $600....
With this kind of mic, it's often the 'law of diminishing returns'......the more expensive mics are obviously better, but probably by not as much as you might think........and if you're plugging directly into a consumer camcorder, then the quality of the internal mic preamps probably won't justify spending out a lot of cash...Last edited by pippas; 17th Jul 2017 at 18:17.
The Pulse Audio link above has changed. Here is their microphone page:
http://www.pulse-audio.co.uk/product-category/audio/microphones/wired/
External mic ???
By cd090580 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 20th Jul 2015, 13:41 -
Help With Using Mic
By fineyoshipie in forum AudioReplies: 11Last Post: 15th Aug 2013, 12:20 -
Mic
By jimmyy in forum Portable VideoReplies: 1Last Post: 19th Jul 2012, 16:04 -
Good wired lavalier mic for 100-200?
By Philip M in forum AudioReplies: 0Last Post: 10th Apr 2012, 20:34 -
Using wireless mic with shotgun mic on Canon HF G10
By jimleben in forum AudioReplies: 5Last Post: 23rd Jan 2012, 20:11
