Thread: Video8 Garbled Audio
  1. #1
    Member
    Oct 2016
    Posts
    6
    I'm currently working on converting some old Video8 tapes to digital, however the tapes all have the same issue where audio is replaced by barely intelligible screeching and humming. (Example attached.) I converted this same tape with this same camera a few months ago and did not have this issue. My current setup is a Sony CCD-TR7 -> Panasonic DMR EH-55 -> HDMI Splitter (For HDCP stripping) -> El Gato Game Capture HD however the same issue happens when I connect the camera directly to the TV as well. I tried cleaning the heads on the camcorder with a microfiber cloth and isopropyl alcohol but it didn't make any difference (or I did it wrong). Any help would be appreciated.
    Mod Neophyte redwudz's Avatar
    USA
    Posts
    24,327
    Re: Video8 Garbled Audio
    Maybe the audio head is separate? Anyway, others here probably know better than I and may respond.
    Member
    Aug 2010
    San Francisco, California
    Posts
    2,350
    There is no separate audio head in 8 mm video. The audio is FM-modulated and laid down with the video signal. Bad audio suggests a tracking problem — but Video8 does not have manual tracking control. Perhaps a tape guide has gone out of alignment, a common problem.
    Member
    Oct 2016
    Posts
    6
    Quote Originally Posted by JVRaines View Post
    How would I be able to tell if this was the problem and what could I do about it?
    Quote Originally Posted by LinkDude View Post
    Since the same camera worked a few months ago, the first thing I would check are the audio cables.
    Next, I looked at the manual for your camcorder:
    TR7 Manual
    There is an input/output switch. That needs to be set correctly.
    Page 54 shows a very important switch labeled "Hi-Fi" sound. It is a three position switch. I'd try all three positions. I'm not a 8mm video expert, but it looks like there are two different types of sound that can be recorded, and if this switch is in the wrong position, you probably won't get anything. I'm betting that this is your problem.
    Member
    Oct 2016
    Posts
    6
    Quote Originally Posted by johnmeyer View Post
    TR7 Manual
    I don't think it's the cable because the same cable works fine with the VCR. I tried the camera again. This time the audio is there but is very quiet and still somewhat garbled. After trying another tape it went back to making screeching sounds but not as loudly as before. I tried what you suggested and flipped the switch. The first green position and position 2 produce garbled audio or quiet but still somewhat garbled audio. Position 1 produces no audio.
    Try moving both audio switches back and forth 8-10 times. Many "electronic" problems are actually mechanical and are caused by slight oxidation of connectors. These really small slide switches are notorious for getting finicky as they get older. Moving them back and forth many times will help to clean the contacts.
    Last edited by johnmeyer; 1st Nov 2016 at 23:27. Reason: forgot to include a key adjective
    Member
    Aug 2010
    Posts
    2,350
    You would have to adjust the guides while a tape is playing and see if the problem goes away. However, you would need special tools and risk wrecking a good alignment. This really is a job for an experienced repair person.
  1. Audio capture problem with video8 tapes.
    By Dutchyyy in forum Capturing and VCR
    Last Post: 26th Aug 2016, 13:34
  2. Video8 / Hi8 Alternate Audio Tracks
    By daave in forum Capturing and VCR
    Last Post: 25th Sep 2015, 18:10
  3. Yahoo Screen -> ffmpeg garbled video
    By nikkar in forum Video Streaming Downloading
    Last Post: 24th Jul 2015, 06:48
  4. Garbled WMV file
    By Eamoe in forum Software Playing
    Last Post: 16th Oct 2014, 01:34
  5. subtitles are garbled
    By wobblyjohn in forum Subtitle
    Last Post: 30th Jun 2012, 08:59
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
