[success] .. see post # 3
After searching around for a Windows 7 driver, I believe to have found one, but am having trouble installing it.
In the device manager windows, the entry for "VideoXpress V2 Analog Capture" has a yellow exlamation point, and the Diginal Signer: says "Not digitally signed".
I read somewhere that you can complete these types of installation but I don't know how.
How do I bypass or over-ride the windows digital signature so that this driver installs ?
I never got the program to work with W7, I installed XP on a unused PC and it worked OK with that.
But you might be able to turn off 'User Account Control Settings (UAC)' and try that.
But turn them back on when not using the program.
Look in 'Control Panel>>Action Center>Change User Account Control settings'.
Also use 'Run as Administrator' when installing. -
solved -- driver installation successful
Hi, I did finally get it working on the laptop with windows 7 home premium 64bit. I just did a few captures. Not bad for a rinky-dink capture card. Its a "hardware mpeg" device about half the size of a cigarette pack. Anyway. It looks good.
I followed these instructions for the digital signature issue, and the driver finally loaded. I was very happy to see it listed in virtualdub.
So, now I can capture lossless with it, too, to my surprise.
f: http://answers.microsoft.com/en-us/windows/forum/windows_7-windows_programs/how-to-i-t...5-8e23d60f3daa
s: How to I turn off digital signature?
To turn OFF the Digital signature do these steps:-
1. Open the Command Prompt window by clicking the Start button, clicking All Programs, clicking Accessories, and then Right clicking Command Prompt and select
"Run as Administrator".
2. On the Command Prompt type in the command “Bcdedit.exe /set nointegritychecks ON” without the quotes.
This will disable the Digital Signature.
For more information on Digital Signature, check this link:
http://windows.microsoft.com/en-us/Windows7/What-is-a-digital-signature
To turn Digital signature on, follow these steps:
2. On the Command Prompt type in the command “Bcdedit.exe /set nointegritychecks OFF” without the quotes.
This will enable the Digital Signature.
Regards -
Good to know. I backed up a dozen or so VHS tapes to MPG video with the device and tossed the tapes
and I am now VHS free.
It was adequate for my purposes after my ADVC-100 died. I still keep the one XP PC around for some old programs.
Removing ads
By kirkmc in forum Newbie / General discussionsReplies: 9Last Post: 6th Oct 2016, 03:25 -
Safari ads need remove
By jowasqw in forum Off topicReplies: 2Last Post: 13th Aug 2015, 03:31 -
PopUnder Ads - Can They Be Blocked?
By wulf109 in forum ComputerReplies: 8Last Post: 22nd Jan 2014, 23:08 -
Weird Banner Ads
By budwzr in forum Off topicReplies: 2Last Post: 7th Nov 2013, 22:10 -
How to remove ads from MPG?
By lovelylisa in forum Newbie / General discussionsReplies: 8Last Post: 28th Jan 2012, 06:15
