Would truly like some help here!
I've tried to take a Flash movie....publish it as a .avi, then tranform it to .mpeg using the recommended tmpge application. Everything seems to be hunky-doory to this point. Mpeg comes out fine. I then used cdcreator Platinium 5 to tranfer to vcd. When burning, I received a "pop-up that source file had been changed" and that some info will be lost. Needless to say, the Cd won't registar on my Sony DVD player that supposedly plays vcd. I then tried Nero 5 in which everything ran smooth.....but still no go.
Deperatly could use some help!
thanks.
That's really odd, because I use the same exact method for publishing flash movies and converting them to mpeg. Here's my exact method...
Flash:
file >> export movie >> and from here I don't change any settings.
Tmpgenc:
All I do is browse for my avi from flash and choose the proper template.
Nero:
I drag and drop after choosing VCD/SVCD and it burns fine.
strange....
Anyone know of any issues w/ sony players?
I have yet to try another dvd/vcd player....that will be my next step.
thanks.
Whats beter than SD600?
By jupita in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 21st Jun 2011, 03:00 -
Whats the best audio codecs to have
By adamf154 in forum AudioReplies: 4Last Post: 7th Apr 2010, 18:31 -
whats authoring?
By templedog in forum Newbie / General discussionsReplies: 3Last Post: 17th Nov 2008, 01:28 -
Whats in the pipeline?
By 2Tents in forum SVCD2DVD & VOB2MPGReplies: 12Last Post: 7th Jul 2008, 12:39 -
Whats the diffrence between these two CD types?
By Megaman00001 in forum MediaReplies: 2Last Post: 19th Jul 2007, 12:21
