    Oct 2016
    So I have my computer hooked up to my TV via an HDMI connection. The aspect ratio on the TV is incorrect when I watch movies played through my computer. When I watch movies on my computer the aspect ratio looks perfect, but when I connect the computer to the TV, the aspect ratios are becoming distorted. Any suggestions?
  2. A Member since June, 2004 Keyser's Avatar
    Feb 2013
    Westernmost point of Europe
    You have to adjust the aspect ratio settings on the TV, either to AUTO or to the desired aspect ratio for each film.
    "The greatest trick the Devil ever pulled was convincing the world he didn't exist."
  3. Member godai's Avatar
    Oct 2012
    United States Florida
    also if your tv and computer have different resolutions , you can get trouble.
    both need be in same resolution, at least for my experience.
    Jan 2007
    humm
    my HP 17 core i5 is 12xx *768 aka 16:9
    my vizio TV is 1920*1080 aka 16:9
    the image is always correct aspect
    its about aspect ratio, NOT pixel resolution
    if both Tv an PC display are 16:9
    something is set wrong, either on the TV or in the dual display settings in windows for the TV 2nd display
  5. Originally Posted by theewizard View Post
    That is more likely to be 16/10 than 16/9, which is more common for computer screens. Without know what number the 'xx' actually are I can't say for sure.
    Last edited by davejavu; 30th Oct 2016 at 18:25. Reason: Rearranged wording and added extra sentence.
    Jan 2007
    pardon me
    its 1600*900 exactly 16:9
    i should have looked before typing
