Hello,
I have bought used Panasonic PV-9661 4-Head Hi-Fi VCR from ebay with a good condition.
When i play VHS Tapes it is play too fast also it display in black and white color. Why ?
Note:
I'm from Kuwait so i used converter adapter to power up the device.
Results 1 to 11 of 11
The pictures I've seen on Google make me think the Panasonic PV-9661 is NTSC.
Is that mean there is no way to play pal taps on NTSC system ?
Note:
I have bought both Panasonic PV-9661 4-Head Hi-Fi VCR & Panasonic DMR-ES15 DVD Recorder
in order to convert VHS tapes into DVD.Last edited by SB4; 29th Oct 2016 at 13:37.
PAL tapes on an NTSC machine? No.
NTSC tapes on a PAL machine? Yes (to WATCH them.....still quite difficult to copy). -
Okay, What should i do to copy this tapes into DVD ?
Note:
I have bought both Panasonic PV-9661 4-Head Hi-Fi VCR & Panasonic DMR-ES15 DVD Recorder in order to do that ? -
If i buy VHS player pal system will that work fine with Panasonic DMR-ES15 DVD Recorder
You will need to have something to remove the
Copy protection on the vcr tape -
Ok, Can anyone give me recomedation for pal system to buy both VHS Play and DVD recorder with TBC feature. Please ?
I can't help you much since i'm NTSC. But this will get you started. I don't know anything about these models (below) so you will have to google each model and read as much as you can.
You could have a look at this one, its a Panasonic NV-SJ210 (PAL) , its a good model, but no TBC. And it will play PAL and NTSC tapes. And it comes with a remote. Most don't.
This model looks similar to my AG-2560 (NTSC).
Also, the NV-FS200 PAL, which is the equivalent of the AG-1980 NTSC model, is a favorite here, but very expensive.
ebay: http://www.ebay.com/itm/Panasonic-NV-SJ210-VHS-VCR-Video-Player-Recorder-PAL-NTSC-Play...UAAOSwNRdX6RIZ
reference: https://forum.videohelp.com/threads/286055-VCR-buying-guide-%28S-VHS-D-VHS-Professional%29
reference: http://www.digitalfaq.com/forum/video-restore/1567-vcr-buying-guide.html#post14567
reference: https://forum.videohelp.com/threads/266232-Which-VCR-is-the-best-for-Restoration?p=1604...=1#post1604405
reference: https://forum.videohelp.com/threads/266232-Which-VCR-is-the-best-for-Restoration?p=1605...=1#post1605330
Consumer Panasonic Pal models with TBC and DNR from older to the last model built:
Panasonic NV-FS 200 (equivalent to the AG-1980 a popular VCR among the UK members, has a good TBC and decent noise reduction)
Panasonic NV-HS 950
Panasonic NV-HS 1000
Panasonic NV-HS 860 (TBC)
Panasonic NV-HS 930
Panasonic NV-HS 960
Panasonic NV-SV 121
ps: please don't post in those old threads i listed above. post your follow-up question in this discussion. if anyone has any answers, they will post there comments here.
Panasonic VCR Settings
By Tafflad in forum Capturing and VCRReplies: 90Last Post: 19th Jan 2025, 15:55 -
VCR comparison Panasonic NV-FS200(AG 1980) VS Panasonic NV-HS1000
By JoseD in forum RestorationReplies: 32Last Post: 18th Apr 2016, 09:30 -
Question about vcr head cleaning
By mazinz in forum RestorationReplies: 14Last Post: 19th Nov 2015, 05:42 -
where to get replacement VCR video head ?
By joecass in forum Newbie / General discussionsReplies: 12Last Post: 4th Jan 2014, 00:54 -
Display drum head usage on Panasonic AG-7750/7650
By Hex Angel in forum RestorationReplies: 0Last Post: 2nd Jun 2013, 19:38
