I am using a newer version of PotPlayer. I don't see how to advance to the next file/movie by clicking on something. In an older version I could do this.
Assuming all of the files are in the same folder, I believe you simply click the >| button (goes to the next chapter / next file). At least it did when I last used it, and it's the same way I progress through files with other media players (such as MPC-HC).
Google is your Friend -
So this is on the keyboard, not on the screen? is there a way to put something on the screen to advance to the next file?
The clue is in the bubble that pops up when you hover over the ">|" button.
Left click: seeks through the playing file
Right Click: Goes to next file
How to advance frame by frame in Potplayer
By idreos in forum Software PlayingReplies: 4Last Post: 10th Jan 2020, 07:25 -
How to remove file information display from Potplayer?
By Mystery123 in forum Software PlayingReplies: 11Last Post: 30th Apr 2016, 10:22 -
Potplayer won't play next file in folder after a while
By Orivaa in forum Software PlayingReplies: 0Last Post: 26th Feb 2016, 10:39 -
Play next file automatically in PotPlayer
By emueyes in forum Software PlayingReplies: 20Last Post: 28th Feb 2014, 03:40 -
Potplayer name of file presists
By gdude in forum Software PlayingReplies: 5Last Post: 24th Apr 2013, 02:25
