When I convert this 300 fps clip into an AVI. I looks fine when I watch it from the Windows Movie Player or whatever but when I drag it into Sony Vegas and watch it from there its really laggy.
Maybe it has to do with the conversion settings I'm using
Here's a screenshot of my conversion settings:
Anyone know a solution to this problem? I'm new to this conversion stuff so I have absolutely no idea what I'm doing lmao
Thanks in advance
	I can't see your attachment
 Is your 300FPS intended to be played at 300FPS, or for something like slow motion , or something else entirely ?
 Most displays in USA refresh at 60 Hz , so you probably only seeing 1/5 of the frames when playing in WMP
 What project settings did you use in vegas ?
 Where is the source video from ? Why did you convert it to AVI? What are the original specs? and what are the converted AVI specs ? Use mediainfo on them, copy & paste the text view (view=>text) back here
	Here's the link for anybody that can't see the image
 https://gyazo.com/a042bca1ef996323437102ed77aee62f
 (in short: x264vfw, CRF 23)
 h.264 (x264vfw) is going to be slow to edit unless you add --keyint 15 in the "extra command line" area. This will make seeking much faster.
 (I just made a quick check in Vegas, and --keyint 15 made an x264vfw clip respond to dragging the playhead about as quickly as a UT Video clip.)
 (EDIT your experience may vary. Windows codec hell and all that.)
 BTW while you are editing the command line, add --colormatrix bt709 for proper colors.
 Also, CRF 23 is fairly low quality for something that is going to be edited and re-encoded. Try CRF 18.
 And zero latency does nothing for you except increase file size. It's for live streaming. Fast Decode might help.
 And Virtualdub hack should be checked if (& only if) encoding with VirtualDub.
 A lossless codec is best for editing, but h.264 with --keyint 15 should be responsive enough and have a smaller file size.Last edited by raffriff42; 26th Oct 2016 at 23:23.
  How to retain video effects and quality of video in Sony Vegas?By YoTiffLBrockz in forum EditingReplies: 10Last Post: 14th May 2014, 00:37
  Blurry video |Sony vegas|By Benjiron in forum EditingReplies: 0Last Post: 9th Jun 2013, 21:33
  How to open an AVI file in Sony Vegas Pro 12?By KyleMadrid in forum Newbie / General discussionsReplies: 7Last Post: 12th May 2013, 23:15
  Will Sony Vegas 11 export to DV-AVI ?By cabruss in forum Newbie / General discussionsReplies: 1Last Post: 23rd Nov 2012, 22:03
  Converted 3GP files into Sony Vegas failBy Blå_Mocka in forum Portable VideoReplies: 0Last Post: 2nd May 2012, 10:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
