Hi, but I'm a c*t. Sorry
I would like do a batch that find a string called AB24EC0DHB inside a file example.avi of 800 GB
The batch should search it inside the file and if at least one occurrance is present ---> change from 0 to 1 the variable AB24Present
Possibly I wonder if there is a faster way to search inside the file: if the occurrance is finded --> the batch have to stop the search and change AB24Present from 0 to 1
How can I do? thanks
set AB24Present=0 & find "AB24EC0DHB" example.avi && set AB24Present=1
can’t merge gopro .mp4: large final file but same length as individual file
By TonyBoulet in forum EditingReplies: 15Last Post: 30th Aug 2016, 17:09 -
how to find "whatever" string lenght and replace
By marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 3rd Apr 2016, 13:49 -
how to find and replace (add a REM) a text string inside a txt file?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 10th Nov 2015, 15:58 -
How to Search Video Menu for Text String in ISO Files
By Jerry22 in forum Newbie / General discussionsReplies: 1Last Post: 19th Jul 2015, 21:39 -
Subtitle Creator error: Input string not in correct format
By kpic in forum SubtitleReplies: 6Last Post: 31st May 2013, 03:17
