What is the recommended method to get this done quick and easy with optimal results
Current libavcodec based converters (using either ffmpeg, or plugins like FFMS2 and L-SMASH Works for AviSynth) can decode HEVC. So you will have a wide choice of converters. Chosing sane x264 options is your own responsibility, though. As you may already know, every conversion to a lossy format will decrease the quality further, only enough bitrate can make the loss less obvious (e.g. CRF encoding with a small factor, possibly 18 or less).
I dont really care, its only meant for playback on legacy devices coupled with old CRT-TVs. The original file will remain on storage. How much time will a laptop with a celeron cpu take for a 20-40 min video clip?
"Old CRT-TV" means only SD resolutions; so, depending on your preferred speed preset, it should be possible in playback time, probably even a bit faster.
"Legacy devices" may have to be discussed more in detail. They may require additional limiting parameters for compatibility.
Try TEncoder for batch processing of many files. It can run several conversions in parallel. But your Celeron may have only few CPU cores, and x264 works multi-threaded too, so that may exhaust your CPU if you try too many. And laptop CPUs may get throttled when they get too hot. Laptops are in general not a recommendable video conversion system.Last edited by LigH.de; 27th Oct 2016 at 01:25.
x264 and x265 - Difference
By THRobinson in forum Video ConversionReplies: 60Last Post: 9th Nov 2016, 13:43 -
moving from x264 to x265
By ben45 in forum Video ConversionReplies: 4Last Post: 16th Aug 2016, 16:26 -
Is x265 ready for Primetime.. Migrating From x264 to x265..
By RazorBurn in forum Video ConversionReplies: 83Last Post: 31st Jan 2016, 07:14 -
x265 vs x264
By deadrats in forum Video ConversionReplies: 71Last Post: 10th Jan 2016, 06:14 -
x264 vs x265??
By xenotox in forum Video ConversionReplies: 167Last Post: 12th Jul 2014, 11:16
