I've recorded two hour's worth of footage in the above mentioned mode (@50fps) and am left with 12 or so separate mp4 files. Obviously I want to join these together for burning to DVD or blu ray. I've imported them into iMovie (10.1.2), joined them and exported them but I now have either a 30gb file (Custom mode) or 112gb (ProRes mode). Ideally I want the file to total no more than the sum of its original files (i.e. 50gb) from the camera. Any ideas how to avoid re-encoding whilst joining the files together for later burning/uploading?
Current versions of iMovie automatically transcode to AIC or Pro Res, so you can't keep the original format without changing software.
On a mac, FCPX is really your best bet. With it you can import your entire card structureand it will automatically stitch the long files for you.
You can also try Davinci Resolve (free) or Adobe Premiere.
Please suggest a good microphone solution for Sony AX53 camcorder
By Srivas in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 4th Oct 2016, 11:05 -
Panasonic HC-VX870 vs Sony FDR-AX33
By glenpinn in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 1st Jan 2016, 21:39 -
Editing XAVC-S Video files
By glenpinn in forum EditingReplies: 18Last Post: 12th Aug 2015, 12:14 -
XAVC S footage
By flashandpan007 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 17th Apr 2015, 20:21 -
What do you think about 4K consumer handycams on the market? (SONY FDR-AX1)
By Stears555 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 3rd Dec 2013, 08:47
