Hi all, new here.
I'm trying to capture a spectrum visualization along with a song I've recorded. The idea being to upload it to sites like youtube
Expresssions attenuates the audio volume unless I keep it too low for my liking.
Next up I decided to replace the poor quality captured audio with the higher quality original but again the volume gets dampened, is there a simple off switch to prevent this.
To replace the audio I reduced the existing audio track to 0
then added the original audio via the enhance/ audio overlay tab
Another thing is I only have the free version of expressions it doesn't export to mp4, is wmv ok for video upload sites?
YouTube has no problem with WMVs — as long as the video is strictly constant-frame-rate, at least.
You should use Expression Encoder for video encoding only. With ffmpeg, or AsfBin, you can replace the bad audio generated by EE with a correctly-encoded WMA stream. -
I came across this type of instruction for ffmpeg
http://stackoverflow.com/questions/11779490/how-to-add-a-new-audio-not-mixing-into-a-v...o-using-ffmpeg
it's gobbledeegook to me
Can someone provide some step by step help please in an alternative user friendly software?
or tell me how to switching off audio dampening in expressions? -
Let's scrap that then.
Are there different freeware capture softwares for windows 7 that are very light on resources.
Will record up to 10mins without watermarks and can save to mp4? -
OBS Studio. You can ignore the streaming feature and just record to a file. Coming off Fraps, it's extremely lightweight.
Thanks, obs looked promising but I get a directx error when I try to record.
From reading around I don't think my gpu is supported, my notebook is too old ...2010
Microsoft owns your content
By sophisticles in forum ComputerReplies: 13Last Post: 1st Jan 2016, 18:15 -
Splitting h264 (no re-enc.), difference mkv and mp4?
By Spiny Norman in forum Video ConversionReplies: 5Last Post: 23rd Dec 2015, 15:48 -
The New Microsoft
By budwzr in forum Off topicReplies: 6Last Post: 3rd Sep 2014, 19:46 -
A UK citizen has sued Microsoft
By enim in forum Off topicReplies: 0Last Post: 18th Jul 2014, 00:27 -
? about Microsoft Visual C++ Redistributable
By sdsumike619 in forum ComputerReplies: 3Last Post: 10th Feb 2012, 20:08
