Hi all,
I have a question about DVD ripping with subtitles. I have some DVDs of a TV show which contain subtitle option, and I wonder how I can rip the DVDs into .avi or .mp4 and also generate .srt for the subtitles.
Please advise, thanks!
HandBrake / Vidcoder.DVDs into .avi or .mp4
Subtitle Edit or DVDSubEditgenerate .srt for the subtitles. -
Converting DVD subtitles to srt is a pain. You need character recognition software and the time to check what it's doing as the subtitles are imported (if you want them to be as accurate as possible). I don't think there's a simple way to do it properly.
As already suggested by videobruger, I use Subtitle Edit. It has quite good options for fixing OCR errors and it'll fix problems such as overlapping subtitles or long single lines etc. The "Tools/Fix Common Errors" menu after importing the subtitles will provide a selectable list of problems Subtitle can check for and offer to fix. The default choices are a good place to start.
Question about getting subtitles when ripping DVD with Vidcoder
By jimdagys in forum SubtitleReplies: 4Last Post: 4th Jan 2016, 15:35 -
Ripping DVD chapter with Subtitles to WMV
By old codger in forum DVD RippingReplies: 3Last Post: 13th Jul 2015, 14:54 -
Ripping SPU subtitles from DVD
By Rugratskid in forum DVD RippingReplies: 7Last Post: 5th Jan 2014, 18:00 -
DVD ripping with switchable subtitles
By jh443 in forum DVD RippingReplies: 3Last Post: 21st May 2012, 15:38 -
Trouble ripping DVD with subtitles
By stig in forum DVD RippingReplies: 9Last Post: 22nd Feb 2012, 06:08
