hello could help me improve this old anime
I want to make a dvdrip but the result is disastrous. I'm using MeGUI
this is a sign of dvds
https://mega.nz/#!5YE2kQIB!Hs5gS-1FHD9-GaUSFsyvNDkqGvZri9-KqJqw9buzfp4
someone will have a script to improve
Thank you .
Results 1 to 10 of 10
I want to achieve dvdrip like this
https://mega.nz/#!NAVVwKJI!JrG9n1H-KhdwR1BFoz8G1pvz5iApWEJol8AbxEnCf6c
I found this on the web dvdrip .. is good ..
It looks good .. but .. the light appears to flicker,
it's dark and brightens suddenly
I want it to look like this but without the light changes.. but I am new to using filters. so I ask for help -
I think the noise reduction is way overdone. All the intentional grain is gone and some details have gone with it. But if you really want something like that:
I made some compromise levels adjustments and white balance adjustments. The automatic gain pumping is going to be hard to deal with. You could try ColorYUV(autogain=true) but that's likely to cause more problems than it's going to fix. A little deshaking might help too.Code:Mpeg2Source("sample.d2v", CPU2="ooooxx", Info=3) TFM(d2v="D:\Downloads\sample.d2v") TDecimate() # white balance ColorYUV(cont_y=60, off_y=15) brights = ColorYUV(off_u=10, off_v=-4) darks = ColorYUV(off_u=-2, off_v=1) Overlay(darks, brights, mask=ColorYUV(cont_y=100)) # convert to HD colors ColorMatrix(mode="rec.601->rec.709") Dehalo_Alpha(rx=1, ry=3) #reduce oversharpening halos on Y axis MCTemporalDenoise(settings="high") # reduce noise and grain #merge duplicate frames Dup(threshold=3, blend=true) # upscale aWarpSharp(depth=5) Sharpen(0.2) nnedi3_rpow2(2, cshift="Spline36Resize", fwidth=1280, fheight=960) aWarpSharp(depth=5) Sharpen(0.3) -
thanks for the help friend , I did not know how to use MCTemporalDenoise
not how to use .avsi in megui
replaces it hqdn3d use it well:
LoadPlugin("C:\...\nnedi3.dll")
LoadPlugin("C:\..\aWarpSharp.dll")
LoadPlugin("C:\...\Dup.dll")
LoadPlugin("C:\...\hqdn3d\hqdn3d.dll")
LoadPlugin("C:\...\RgTools.dll")
LoadPlugin("C:\...\mt_masktools.dll")
LoadPlugin("C:\...\tivtc_20071121\TIVTC\TIVTC.dll" )
LoadPlugin("D:\...\DGDecode.dll")
DGDecode_mpeg2source("C:\...\sample.d2v", info=3)
LoadPlugin("D:\...\avisynth_plugin\ColorMatrix.dll ")
ColorMatrix(hints=true, threads=0)
#deinterlace
#crop
LanczosResize(656,480) # Lanczos (Sharp)
#denoise
TFM(d2v="C:\...\sample.d2v")
TDecimate()
# white balance
function DeHalo_alpha(clip clp, float "rx", float "ry", float "darkstr", float "brightstr", float "lowsens", float "highsens", float "ss")
rx = default( rx, 2.0 )
ry = default( ry, 2.0 )
darkstr = default( darkstr, 1.0 )
brightstr = default( brightstr, 1.0 )
lowsens = default( lowsens, 50 )
highsens = default( highsens, 50 )
ss = default( ss, 1.5 )
LOS = string(lowsens)
HIS = string(highsens/100.0)
DRK = string(darkstr)
BRT = string(brightstr)
ox = clp.width()
oy = clp.height()
uv = 1
uv2 = (uv==3) ? 3 : 2
halos = clp.bicubicresize(m4(ox/rx),m4(oy/ry)).bicubicresize(ox,oy,1,0)
are = mt_lutxy(clp.mt_expand(U=uv,V=uv),clp.mt_inpand(U= uv,V=uv),"x y -","x y -","x y -",U=uv,V=uv)
ugly = mt_lutxy(halos.mt_expand(U=uv,V=uv),halos.mt_inpan d(U=uv,V=uv),"x y -","x y -","x y -",U=uv,V=uv)
so = mt_lutxy( ugly, are, "y x - y 0.001 + / 255 * "+LOS+" - y 256 + 512 / "+HIS+" + *" )
lets = mt_merge(halos,clp,so,U=uv,V=uv)
remove = (ss==1.0) ? clp.repair(lets,1,0)
\ : clp.lanczosresize(m4(ox*ss),m4(oy*ss))
\ .mt_logic(lets.mt_expand(U=uv,V=uv).bicubicresize( m4(ox*ss),m4(oy*ss)),"min",U=uv2,V=uv2)
\ .mt_logic(lets.mt_inpand(U=uv,V=uv).bicubicresize( m4(ox*ss),m4(oy*ss)),"max",U=uv2,V=uv2)
\ .lanczosresize(ox,oy)
them = mt_lutxy(clp,remove,"x y < x x y - "+DRK+" * - x x y - "+BRT+" * - ?",U=2,V=2)
return( them )
function m4(float x) {return(x<16?16:int(round(x/4.0)*4))}
hqdn3d(ls=8.0, cs=3.0, lt=6.0, ct=4.5, restart=7)
# upscale
aWarpSharp(depth=5)
Sharpen(0.2)
aWarpSharp(depth=5)
Sharpen(0.3)
It is the result
https://mega.nz/#!xUdxgaQQ!v-j1H7SUqwPDm0iZaD3Ea0fGaOMKyOfZcjxSumoc9_oLast edited by fulmanful; 24th Oct 2016 at 14:22.
Yes thanks . use it well
LoadPlugin("D:\...\TTempSmooth.dll")
LoadPlugin("D:\...\mvtools2.dll")
LoadPlugin("D:\...\gradfun2db.dll")
LoadPlugin("D:\...\FFT3DFilter.dll")
LoadPlugin("D:\...\ColorMatrix.dll")
LoadPlugin("C:\...\aWarpSharp.dll")
LoadPlugin("C:\...\TIVTC\TIVTC.dll")
Import("D:\...\LSFmod.v1.8.avsi")
Import("D:\...\MCTemporalDenoise.v1.4.20.avsi")
DGDecode_mpeg2source("C:\...\sample.d2v")
#deinterlace
#crop
LanczosResize(640,480) # Lanczos (Sharp)
#denoise
TFM(d2v="C:\Users\mane y ale\Desktop\hukoto no ken 10 bits\sample.d2v")
TDecimate()
# white balance
ox = clp.width()
oy = clp.height()
uv = 1
are = yv12lutxy(clp.expand(U=uv,V=uv),clp.inpand(U=uv,V= uv),"x y -","x y -","x y -",U=uv,V=uv)
ugly = yv12lutxy(halos.expand(U=uv,V=uv),halos.inpand(U=u v,V=uv),"x y -","x y -","x y -",U=uv,V=uv)
so = yv12lutxy( ugly, are, "y x - y 0.001 + / 255 * "+LOS+" - y 256 + 512 / "+HIS+" + *" )
lets = maskedmerge(halos,clp,so,U=uv,V=uv)
\ .logic(lets.expand(U=uv,V=uv).bicubicresize(m4(ox* ss),m4(oy*ss)),"min",U=uv2,V=uv2)
\ .logic(lets.inpand(U=uv,V=uv).bicubicresize(m4(ox* ss),m4(oy*ss)),"max",U=uv2,V=uv2)
them = yv12lutxy(clp,remove,"x y < x x y - "+DRK+" * - x x y - "+BRT+" * - ?",U=2,V=2)
return( them )
# upscale
aWarpSharp(depth=5)
Sharpen(0.2)
aWarpSharp(depth=5)
Sharpen(0.3) -
one last question . if I use this script with this other dvds edition
this line mark me error :
TFM(d2v="...")
TDecimate()
the error is this : TFM: d2v frame does not match filter frame count -
By the way, there's no reason to resize to 640x480 at the start of the script. Just leave the video at 720x480. Resize only once as each resize may reduce the quality.
The TFM error may be because you're using the wrong d2v file (I downloaded your new file and got no errors). Use the same d2v file used in Mpeg2Source. You don't really even need to include the d2v parameter. Just use TFM().Last edited by jagabo; 24th Oct 2016 at 18:06.
Question about dvdrip movies
By lukasz12054 in forum DVD RippingReplies: 15Last Post: 30th Sep 2016, 14:37 -
1024x576 DVDRip?
By Knocks in forum Newbie / General discussionsReplies: 35Last Post: 31st Jan 2015, 15:41 -
Questions regarding anime DVDRip
By newborn in forum Video ConversionReplies: 6Last Post: 11th Jun 2012, 06:09 -
DVDRIP vs Original DVD
By Smith79 in forum DVD RippingReplies: 6Last Post: 1st Jan 2012, 01:50 -
DVDrip Settings
By hardy in forum Newbie / General discussionsReplies: 4Last Post: 30th Nov 2011, 11:58
