I compiled libdvdcss from the latest source code into /usr/local/lib:
When I try to use the Handbrake client to run I receive the following error message below.Code:./configure --prefix=/usr/local make sudo make install
The file permissions on the files are:Code:ERROR: libdvdcss.2.dylib command tool is not setup to execute ERROR: attempting to use tool at /usr/local/lib/libdvdcss.2.dylib
I'm running Mac OS Sierra 10.12.Code:zeus:lib sitrucz$ ll total 312 drwxr-xr-x 7 root wheel 238 Oct 23 09:50 . drwxr-xr-x 7 root wheel 238 Sep 24 07:53 .. -rwxr-xr-x 1 root wheel 41936 Oct 23 09:50 libdvdcss.2.dylib -rw-r--r-- 1 root wheel 104336 Oct 23 09:50 libdvdcss.a lrwxr-xr-x 1 root wheel 17 Oct 23 09:50 libdvdcss.dylib -> libdvdcss.2.dylib -rwxr-xr-x 1 root wheel 921 Oct 23 09:50 libdvdcss.la
Stand by. It sometimes takes a day or two for our Mac members to reply.
And welcome to our forums. -
My v1.4.0 source compiled to an 41952 bytes library file. Not sure why that's different from yours. Permissions on my side also detected as -rwxr-xr-x root wheel. Other files in /usr/local/bin/lib and /usr/local/bin/ seem to be linked to <username> staff, instead of root wheel. Not sure if that is important or not.
Having a bit of problems with my DVD drive, so I haven't actually tested ripping. -
Thanks for the help but that didn't work. I think my only option is to disable sip unless anyone has further suggestions. My binary total matched yours once I compiled out of git. I've tried Macports and Brew and I receive the same error message.
Handbrake AnyDVD and libdvdcss
By Teac23 in forum Video ConversionReplies: 1Last Post: 2nd Aug 2015, 08:51 -
Cannot rip TV shows with handbrake x86 or x64 with libdvdcss
By Yanta in forum DVD RippingReplies: 2Last Post: 15th Jan 2015, 03:54 -
Mac or PC
By poacher in forum ComputerReplies: 11Last Post: 30th Jan 2014, 12:37 -
I have Mac OS X and need help with....
By nateo200 in forum MacReplies: 6Last Post: 11th Dec 2011, 04:04 -
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 05:04
