In the Kodi Media Player settings ( under Settings > Video > Accessibility ) I find settings marked (for example) "Prefer audio stream for the visually impaired".
Assume I'm converting a TV show with descriptive audio to the MKV format, preserving the video, audio 1 (surround), and audio 2 (stereo descriptive for the visually impaired) tracks in the resultant file. What would I name the audio 2 (stereo descriptive for the visually impaired) track for Kodi to recognize it as such?
There are also settings for "Prefer subtitles for the hearing impaired" and "Prefer audio stream for the hearing impaired" that I'm curious about.
Google has not helped.
I'm not currently using KODI, but I think those settings may only work for live TV broadcasts or maybe TS files.
I don't use MKV files often, but I've only ever heard of setting a default audio stream in the file itself and cycling through the others manually if a different audio stream is desired instead. There is a way to set the default audio track for MKV files. https://forum.videohelp.com/threads/313455-How-to-delete-switch-default-language-in-a-M...=1#post2376758 -
It's not working when I watch live TV either. I'm in the US watching ATSC over an antenna and (so far) the shows default to the surround channel.
I'd rather not mess with the defaults in the mkv files themselves. So far I've been using MKVMerge to set the visually impaired track name to "Descriptive" (and the track language to English as needed). -
If you want the descriptive audio to be the default then you need to make it so in the MKV file - change forced track flag to YES. If you prefer the normal audio track then you would need to manually change it in KODI.
Trouble Playing MP4 files in Kodi on Android
By Chopmeister in forum Media Center PC / MediaCentersReplies: 4Last Post: 8th Sep 2017, 02:35 -
Re: Having issues with kodi 15.2 and MXBox
By Richiemxbox in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2016, 09:23 -
kodi xbmc pseudtv lite
By bermuda in forum Newbie / General discussionsReplies: 2Last Post: 4th Mar 2015, 16:26 -
Setting Up a NAS to Stream to XBMC/Kodi
By Chopmeister in forum Media Center PC / MediaCentersReplies: 0Last Post: 14th Dec 2014, 00:38 -
Help with converting sports broadcasts with vidcoder
By jerecho in forum Video ConversionReplies: 6Last Post: 20th May 2013, 07:07
