  1. Hey!
    I'm trying to compress videos from old camera to h264, but I'm unable to play those on my TV ue40es6100. Some h264 movies downloaded from internet are played ok on this TV, but not movies that I converted.
    TV manual (on page 667) shows:
    Video decoder
    ● Supports up to H.264, Level 4.1.
    ● H.264 FMO / ASO / RS, VC1 SP / MP /
    AP L4 are not supported.
    ● For all Video codecs except VP8, VP6:
    – Below 1280 x 720: 60 frame max
    – Above 1280 x 720: 30 frame max
    ● GMC is not supported.
    ● Supports only SVAF Top/Bottom and
    Side by Side.
    Audio decoder
    ● WMA 9, 10 Pro supports up to 5.1
    channel and M2 profile (except LBR
    mode of M0).
    ● WMA lossless audio is not supported.
    ● If Vorbis is only in Webm container,
    supports up to 2 channel.
    Also in attachments there is supported codecs table
    Here is mediainfo output about converted movie:
    General
    Complete name                            : MVI_4299.MP4
    Format profile                           : Base Media
    Codec ID                                 : isom
    File size                                : 19.7 MiB
    Duration                                 : 32s 686ms
    Overall bit rate                         : 5 063 Kbps
    Writing application                      : Lavf57.41.100
    Video
    Format profile                           : High 4:2:2@L4.1
    Format settings, ReFrames                : 4 frames
    Codec ID                                 : avc1
    Codec ID/Info                            : Advanced Video Coding
    Duration                                 : 32s 500ms
    Bit rate                                 : 5 037 Kbps
    Width                                    : 640 pixels
    Height                                   : 480 pixels
    Display aspect ratio                     : 4:3
    Frame rate mode                          : Constant
    Frame rate                               : 30.000 fps
    Chroma subsampling                       : 4:2:2
    Bits/(Pixel*Frame)                       : 0.547
    Stream size                              : 19.5 MiB (99%)
    Writing library                          : x264 core 142 r2431 a5831aa
    Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Audio
    Format                                   : AAC
    Format/Info                              : Advanced Audio Codec
    Format profile                           : LC
    Codec ID                                 : 40
    Duration_LastFrame                       : 85ms
    Bit rate mode                            : Constant
    Bit rate                                 : 51.6 Kbps
    Channel(s)_Original                      : 1 channel
    Channel positions                        : Front: C
    Sampling rate                            : 11.025 KHz
    Stream size                              : 206 KiB (1%)
    I tried a couple of ffmpeg commands i.e.:
    ffmpeg -i input.avi -c:v libx264 -preset medium -crf 23 -profile:v high -level:v 4.1 -c:a aac output.MP4
    Could you point me correct ffmpeg command, so I could watch that video on my TV?
  2. 4:2:2 is seldomly supported. Try 4:2:0:
    ffmpeg -i input.avi -c:v libx264 -preset medium -crf 23 -profile:v high -level:v 4.1 -pix_fmt yuv420p -c:a aac output.MP4
  3. It's working now! Thank you very much!
