And to add the the comedic value of it all, now you're continually explaining that you've explained what you meant, and again explained you've provided evidence that a problem exists when nobody has argued about it. Not all NTSC Bluray players play 25fps Bluray discs. We agreed on that 25 posts ago. Let it go and move on.
If you agree media players work for the content in question, I'll ask once more. What are you arguing about? And no they don't "typically" work until you provide an example of one that doesn't. Until then the "do" work.
Which probably has nothing to do with the frame rate of the video unless they're ignorant enough to question why they can't play a PAL DVD on NTSC equipment or why their NTSC Bluray player won't play a 25fps Bluray disc. "Not supporting" a particular standalone file format or video type would almost never have anything to do with frame rate, despite the bad advice you might consistently offer. Why do you keep going on about it as though it would?
You can keep avoiding the question for as long as you feel like looking foolish. Can you provide an example of a player that'll play a 24fps 1080p MP4 but won't play the same video if it's 25fps. I'm still waiting.....
Results 31 to 41 of 41
I agree with that as well.
I should not have allowed myself to be drawn into an off-topic argument that was based on one off-hand remark I made about people living in countries outside N. America not needing to worry about HD video frame-rates.
@hello-hello: Not only am I not replying, I'm putting you on my ignore list, seeing as how you are a jackass who continues to argue with people even after they repeatedly say they agree with you.Last edited by usually_quiet; 27th Oct 2016 at 14:11. Reason: My typing has gone to hell
Or you could have been grown up enough to admit you were wrong.
Oh dear. Another forum baby using the ignore list as a substitute for discussing a topic like a grown up. Putting me on your ignore list because you're accusing me of doing exactly what you're doing yourself. Mental.... although it seems reasonable you'd be a member of the same club as sameself.
I guess I'm supposed to be upset by that, or care, or something.....Last edited by hello_hello; 28th Oct 2016 at 10:09.
To quote the bard: "A pox on both your houses."
What a bunch of gibberish, none of it answering the OP's question, little of it correct, and all of it ignoring anything that anyone else said.
As Monty Python used to say, "this sketch has become too silly." [cut to black]Last edited by johnmeyer; 27th Oct 2016 at 20:18. Reason: Changed last sentence
Wow. I guess you want to take on all comers. Anyone else want to post in this thread?
P.S. You also should note that you have been so intent on "winning" a pointless and silly argument that you completely missed all three of my posts, every one of which tried to answer the OP's question and none of which "are related to the argument you are complaining about." Here are the links to my other posts in this thread:
https://forum.videohelp.com/threads/380969-media-info-says-NTSC-for-PAL?p=2463732&viewf...=1#post2463732
https://forum.videohelp.com/threads/380969-media-info-says-NTSC-for-PAL?p=2463749&viewf...=1#post2463749
https://forum.videohelp.com/threads/380969-media-info-says-NTSC-for-PAL?p=2464116&viewf...=1#post2464116
I realize that the OP's initial post was about an errant Mediainfo reading, but it implied that the video might not be playable on his equipment.Last edited by johnmeyer; 27th Oct 2016 at 22:11.
The OP deliberately set his camera to record using what he said were PAL settings. Given that, what made you think he would be watching it on a TV made for the N. American market, which is where I said there can be problems playing HD video with "PAL" framerates? People keep telling me there are no problems watching HD video with NTSC framerates in former PAL counties, using any playback device and any HDTV purchased in those countries.
Also, your two out of three of the links above were replies to something I wrote. Silly me, thinking they were directed at me rather than Sounds, the OPLast edited by usually_quiet; 27th Oct 2016 at 23:08.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
I think MediaInfo is reading this value from the video stream header. According to the h.264 standard, there is a video usability information (VUI) attribute called video_format which is pertinent only with SD resolutions. Perhaps your camera defaults this value to "NTSC" and doesn't bother to change it when recording HD video. Better behavior for MediaInfo would be to omit this attribute when the material is not SD.
There's only one thing funnier than a "can't be wrong" putting someone on their ignore list because they're having a tantrum, and that's advertising it in their signature as though someone might care.
That's definitely one of the funnier things I've read in a while. Almost a tad mental. Who mentioned frame rates and NTSC in the first place????
Edit:
JVRaines,
Sorry (in case you read my initial post already), after a re-think I realised I misinterpreted your post and the VUI attribute "video_format" you refereed to is something different to the colormatrix VUI attributes I initially referred to when replying, so I've deleted my reply.Last edited by hello_hello; 28th Oct 2016 at 10:10.
I asked google about the video_format attribute JVRaines referred to and found this:
https://web.archive.org/web/20150203203142/http://mewiki.project357.com/wiki/X264_Sett...gs#videoformat
I also found someone else asking the same question:
http://forum.doom9.org/showthread.php?t=170621
But not an answer as to why "NTSC" is possibly being written for HD video.Last edited by hello_hello; 28th Oct 2016 at 06:04.
As it doesn't apply to HD content, that's why I suggested he contact the creator. It's likely a default value for a field that wan't designed to be empty.
Google is your Friend
DVD PAL to NTSC or NTSC to PAL DVD Conversion
By Baldrick in forum DVD RippingReplies: 21Last Post: 12th Apr 2016, 18:30 -
help needed Ntsc(PAL) dvd to Ntsc
By spiritgumm in forum Video ConversionReplies: 19Last Post: 23rd Nov 2015, 19:19 -
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
PAL or NTSC for NTSC-sourced material?
By emilroh in forum Newbie / General discussionsReplies: 12Last Post: 16th Nov 2013, 17:29 -
Media Info Not seeing all subtitles
By cal_tony in forum SubtitleReplies: 0Last Post: 15th Apr 2012, 23:43
