I'm using WinAVI v11 I was previously using an earlier version and I've noticed that quite frequently with this new version there's no sound on my conversions.
I'm always converting to avi.
I'm pretty sure it's a matter of not having the proper codecs with this new version. Does anyone have any idea how I can find out what codecs I need. and where I can get them. I think a lot of the time the file I'm converting when this happens is mkv but there might have been some mp4s in there as well I wasn't really paying attention when it started because I didn't realize it was now a thing since it never was with the last version I used.
Hi LigH.de hopefully you see this.
Here's an mkv file that had no sound when I tried to convert it to avi in WinAVI.
Here's the MediInfo analysis of the Source
General
Unique ID : 173456839220550822876898010948008781785 (0x827E927344CF43DF80326583AE69A7D9)
Complete name : F:\Movies\Flight 1942 (2016) WS DVDRip.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 564 MiB
Duration : 1 h 21 min
Overall bit rate : 965 kb/s
Encoded date : UTC 2016-04-10 09:08:04
Writing application : mkvmerge v9.0.1 ('Obstacles') 32bit
Writing library : libebml v1.3.3 + libmatroska v1.4.4
Video
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Width : 720 pixels
Height : 404 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core 148 r2665 a01e339
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=17500 / vbv_bufsize=17500 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:0.60
Default : Yes
Forced : No
Audio
Format : AAC
Format profile : LC
Codec ID : A_AAC
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 spf)
Compression mode : Lossy
Delay relative to video : 9 ms
Language : English
Default : Yes
Forced : No
Here's the result analysis
General
Complete name : C:\1\Flight 1942 (2016) WS DVDRip.avi
Format : AVI
File size : 631 MiB
Overall bit rate : 1 079 kb/s
Writing application : Lavf52.57.1
Video
Format : MPEG-4 Visual
Codec ID : FMP4
Bit rate : 1 073 kb/s
Width : 640 pixels
Height : 360 pixels
Frame rate : 29.970 FPS
Color space : YUV
Bits/(Pixel*Frame) : 0.155
Stream size : 627 MiB (99%)
Apparently there was no audio encoded at all. I have no idea why it's the exact same settings I use for all my other conversions (except for file size and dimensions of course) and they work perfectly 98% of the time.
I did use AAC. I also tried mp3, ATSC, mp2, and PCM whatever that is. All produced no sound.
Hope you get to see this.
CheersLast edited by KT888; 15th Nov 2016 at 15:06.
Just a small piece in addition: The target audio format doesn't matter much if the converter of your choice is unable to handle the source audio format. Seems to be the case here. The more elaborate the GUI, the less I trust the features. There is probably more powerful real freeware.
Thanks for responding LigH.de
WinAVI isn't freeware but I guess I'll have to find an alternative. MediaInfo says the source audio format is AAC which WinAVI does have support for. What is it specifically that is non-standard so that WinAvi's support does not include this file. Do you see something in the source info that tells you what exactly is not supported?
Any suggestions on an better alternate
Missing / Faulty Codecs.
By iceman1 in forum Newbie / General discussionsReplies: 2Last Post: 5th Nov 2015, 06:51 -
Display problem after pc upgrade (codecs missing?)
By boko in forum Newbie / General discussionsReplies: 1Last Post: 29th Apr 2014, 02:59 -
WinAvi no sound / no audio problem - solution
By bukimi in forum User guidesReplies: 2Last Post: 9th Jul 2012, 14:50 -
Missing codecs after update of K Lite
By Zoro83 in forum Newbie / General discussionsReplies: 7Last Post: 9th Apr 2012, 10:46 -
VirtualDub Compression Codecs All missing?
By blazr in forum Newbie / General discussionsReplies: 0Last Post: 29th Feb 2012, 05:14
