I use my HTS (downstairs) to watch sitcoms on my PC (upstairs.)
I have an ADSL router with WiFi. The Home theatre has a WiFi to ethernet adapter. The PC is logged in to the WiFi. Don't know if this is relevant to the problem.
On the HTS some filenames show up different to the filename on the PC. The ID3 tags are correct. MediaInfo shows the correct info in Movie Name. In Properties->Details the Title is correct. Yet they show up as just the episode name, not preceded by the season-episode number, which is inconvenient.
Don't know where else to check for the correct name.
The HTS is an LG.
Windows 10.
There are ID3v1 tags (at end of file) and ID3v2 tags (usu. at begin of file). Both can specify (roughly) the same metadata, but they are incompatible with and independent of each other. So you can have the same or conflicting or missing info on one and/or the other.
My guess is one device is referencing using one version and the other is using the other version.
Eg:
LG -> ID3v2, sees "Elvis Costello - Radio, Radio - My Aim Is True"
PC -> ID3v1, sees "Costell, Elvis - Beyond Belief (rip) - "
(Not only is the formatting different on the common data, but there is conflicting AND missing info)
Have seen this happen a number of times. What you need to do is use an ID3tag editor that supports BOTH versions and allows you to port data from one type to another type (or vice-versa), and even take data from the filename. AKA "sync" the metadata.
Scott -
You have mentioned tag info and you have mentioned filenames. Just like I mentioned earlier, tags & filenames can be and often are different. They're independent. Plus there are long & short filenames and even filename differences between filesystems.
And Win10 may show the "filename" in the base implementation of a file manager, but if it understands the folder refers to media files, it can alternately work more like iTunes (media cataloguing) and report naming via its tag "properties".
So we just want to be real clear & detailed here.
Can you give/post an example?
Scott -
While gathering data I noticed a problem with WMP. The folder containing the "problem" files does not show up in WMP. All the other folders on that drive do.
Created a temp folder and moved the files to that folder. The temp folder also does not show in WMP. Will have to investigate this first.
BTW, the current folder structure existed before my PC was upgraded from WIN7 to WIN10.
EDIT: Trying out Emby in place of WMP as the DLNA server.
EDIT2: Using Emby fixed the problem. There was something funny about WMP. I noticed that if I removed K:\Sitcoms2 from the library, it was left with K: in the library. All other HDDs worked fine. Weird.Last edited by NDMMackay; 22nd Oct 2016 at 12:11.
youtube-dl: change ouput filenames of multiple streams of a video
By flashandpan007 in forum Video Streaming DownloadingReplies: 11Last Post: 14th Aug 2015, 06:49 -
Philips HTS 3400 hack code for Brazil
By Scott Brazil in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Oct 2014, 16:18 -
hts format used by Humax
By bjkempston in forum Video ConversionReplies: 3Last Post: 25th Jul 2014, 14:13 -
Filenames as subtitles in slideshow
By schematic2 in forum Authoring (DVD)Replies: 2Last Post: 10th Dec 2012, 23:22 -
recover recycled photos with filenames??
By piano632 in forum ComputerReplies: 1Last Post: 3rd Dec 2011, 21:28
