I have a TS video with problems. The video contains commercials that are a different resolution and bit rate than the main video.
The TS video won't play in VLC, Avidemux, or most of my other players. It will play if I re-encode it to MP4, but the audio is out of sync with the video.
The TS video will play in SMPlayer and FFplay, and the audio is in sync until it gets to commercials. After commercials the audio is delayed--the amount of delay is close to the length of the commercials.
In SMPlayer, the elapsed time is shown on the toolbar. The total video time is not shown--it stays at 00:00:00--and the slider doesn't work. I can move forward or backward in the video using the keyboard shortcuts. The elapsed time works until it gets to commercials, where it gets stuck. For example, some commercials start at 36:02. While the commercials are playing, the elapsed time fluctuates quickly between 36:02 and 36:03. After the commercials end, the elapsed time advances normally, but the audio is delayed. Using the keyboard shortcuts to go backward or forward a few seconds, causes the audio to get back in sync with the video. It gets out of sync again every time it hits the commercials.
Similarly in FFplay, the TS video plays and the audio and video are in sync until it gets to commercials. And after the commercials, using the keyboard shortcuts to move backward or forward a few seconds, causes the audio to go back in sync with the video.
How do I fix this?
Is there a way to fix it with FFmpeg?
TSDoctor should fix it for you. If it is not H264 but standard definition ie mpeg2 transmission then the free program ProjectX wil fix the timing problems. ProjectX interface has been described as toxic! But it is an excellent program for fixing standard definition TS files. TSDoctor will do either standard definition or HDTV but it is payware if that is an issue.
Video/Audio sync problems with Hauppauge USB-Live2 & Vdub
By liddle in forum Capturing and VCRReplies: 36Last Post: 27th Feb 2026, 09:37 -
Video/audio sync changes each time I play it
By shokan22 in forum Newbie / General discussionsReplies: 1Last Post: 26th Jul 2015, 10:15 -
audio video audio sync problems
By prasoon kumar in forum Video ConversionReplies: 1Last Post: 24th Feb 2015, 02:26 -
Having problems to sync video with audio
By synnchan in forum Newbie / General discussionsReplies: 6Last Post: 12th Aug 2014, 11:46 -
Demux audio from ntsc video and mux with pal,audio sync problems
By luis67 in forum AudioReplies: 6Last Post: 17th Nov 2012, 04:43
