When I shoot with HC-X920 and press the "rec" button I get the camcorder to pause. Pressing the "rec" button again creates a new scene. The scenes are separate and do not playback continuously as it used to be tape camcorders. When I transfer these onto PC the same separateness is maintained. Is there a way I can stitch these files together, so they can playback smoothly without the need to click on every file?
With most video editors, you 'append' the individual parts of your video to combine them into a single output video.
AviDemux is one editor you might try. I assume the camcorder uses AVC format.
Other similar editors: https://www.videohelp.com/software/sections/video-editors-h264-avc
Some have a 'batch' feature where all parts can be dropped in and combined,
or a 'watch folder' where everything in it is converted automatically when the folder is selected as input.
The downside to that is your files need to be numbered sequentially to be joined in the proper order.
Other members here may be able to give you more specific advice or suggestions. -
Thank you both, The software bundled with the camcorder has a serious downside. Once you use it to copy files from the camera, you cannot copy again if you need to reload the files. They stay in the camera card but cannot be copied. For that reason I decided not to use itl
Panasonic HC-X920 Camcorder (poor) manual
By Epicuros in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 16th Oct 2016, 13:37 -
Audio glitch on full HD Panasonic X920 - oppinion and help
By Stile in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 18th Jun 2016, 19:08 -
Panasonic HC-X920 and remote controll
By Stile in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 14th May 2016, 19:12 -
Panasonic HC-X920 faults
By 2Bdecided in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 23rd Jul 2014, 05:28 -
Panasonic x920 advice plz
By Londonshooter in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 22nd Jul 2014, 05:18
