Right-click on Desktop or Control Panel -> Display -> Display Properties -> Desktop -> "Stretch" <- Keeps changing to "Center" every time I turn computer on, , , annoying.
Remembers every other setting, , ,
Ideas?
-corne-
(XP-Pro 64 bit)
Results 1 to 10 of 10
Yes, no, maybe, I don't know, Can you repeat the question?
27" Samsung monitor (S27D360): has setting for 'wide' or 'auto'. Manual sez set resolution in control panel. It remembers everything in display settings (ie 1600-900) except 'stretch', allus reverts to 'center' on power-up. I have a bunch of wallpapers of different dimensions & scaling allus 'blurs' them, never as good as unscaled. Some are 16-9, & they fit just fine, , , duh.
-c-Yes, no, maybe, I don't know, Can you repeat the question? -
Surely the resolution of the monitor (in pixels) is 1920 * 1080. Any other setting could confuse.
Why not just resize the images to the correct size for your screen? It'll solve your problem.
Windows xp display settings are controlled by desktop themes not display settings
Change it and save as new
Then set it as the default
That should be all that's needed -
I dont care what the 'optimum (native) resolution" is, the image would then fit, but then icons are too small for me, text is waay too small, resized images (using paintdotnet) get degraded, I've saved 'theme' more times than once, it is default, (shows as (named theme), still, restarts are 'center' not stretch.
"That should be all that's needed" It should be, but its not, , , ,
This is not an issue on my other comps, none of 'em are set at native rez, , , they work like I want.Yes, no, maybe, I don't know, Can you repeat the question? -
But there are display settings for larger text and larger icons ??????
When I upgraded my 1024 monitor to a 1920 one, I also had 'small' issues especially with browsers. But the solution exists without messing around with a display setting that, possibly, your GPU does not totally support.
Maybe a little more info might assist. Graphics card etc. -
ATI cards commonly screw this up.
XP-64 is a goatscrew I wouldn't touch with a 10-foot pole. Just researching the driver history for your card should show you why. -
Grafix card is "asus hd 5450 silent". Mobo 'ecs nforce6m-a' 8 gigs ram.
Installed 18 months ago, worked fine till 2 weeks ago. Reinstalled drivers, nada.
Win 10 not a goatscrew??? I have one comp with W7. Tried 10 for about 23 1/2 hours, , ,
Potplayer - remember playback speed setting for multiple files
By OldGeek in forum Software PlayingReplies: 6Last Post: 28th Apr 2016, 06:44 -
Computer monitor calibration - Spyder4Pro vs Colormunki Display?
By liddle in forum Newbie / General discussionsReplies: 7Last Post: 30th Mar 2015, 10:40 -
wlmm - video clips display do not display correctly?
By OleMan in forum EditingReplies: 7Last Post: 12th May 2013, 10:32 -
Why Computer monitor doesn't have capability to display interlaced video
By Aston in forum Newbie / General discussionsReplies: 51Last Post: 15th Mar 2013, 06:47 -
What is an OK bit rate setting for computer videos?
By johnharlin in forum Video ConversionReplies: 3Last Post: 17th May 2012, 12:35
