Hi.
I was Indexing a .ts for VirtualDub, when this message popped out.
https://forum.videohelp.com/images/imgfiles/1bkKicZ.png
Fixing the problem immediately or later will create a "fixed.D2V".
But using this "fixed.D2V" in VirtualDub will lead to an audio desynch.
The ".D2V.bad" will not even work.
I tried Mpeg2Repair but without any success.
I tried AutoGK but after getting 2 (??) audio tracks, it says the audio was not found.
https://forum.videohelp.com/images/imgfiles/oYVeTcY.png
I can't change source, so is there any way to fix the .ts and correctly index it?
Thanks in advance for the help.
No, it doesn't. Your audio might be out of synch but it's not because of what you did or did not do with the D2V. Maybe 99% of the time you want to hit 'Yes' when asked the question. And it's not as if audio asynch can't be fixed.
Some people run their TS captures through something to fix them. I don't capture from television so maybe someone will see this and respond. -
What kind of audio desync ? Constant or progressively worsening ?
Was there a delay value written in the audio name, and did you account for it in your script ?
swap field order in avisynth
By marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 20th Sep 2014, 15:04 -
how to invert field order with ffmpeg
By marcorocchini in forum Newbie / General discussionsReplies: 7Last Post: 18th Jun 2014, 22:19 -
Which field order should I specify for reinterlacing?
By brassplyer in forum EditingReplies: 43Last Post: 7th Sep 2013, 02:07 -
Field order issue -
By Spektre in forum Capturing and VCRReplies: 9Last Post: 29th Apr 2013, 11:24 -
AVI Field Order
By Ash McKenzie in forum Newbie / General discussionsReplies: 1Last Post: 1st May 2012, 01:52
