  1. when i load a vob in dvd2avi and for the film type it says 29,97 fps and film, should i load a ntscfilm template in tmpgenc?
  2. YOU NEED TO LOOK AT THE PERCENTAGE. IF IT SAYS FILM WITH A PERCENTAGE OF 95% OR HIGHER THEN YOU NEED TO USE FORCE FILM IN DVD2AVI AND THEN USE THE FILM TEMPLATE IN TMPGENC. iF NOT THEN DON'T USE THE FILM TEMPLATE.
  3. you will find that you will probably use the Force Film option in dvd2avi 99% of the time. I have always used this option. Then just load the NTSCFilm template.
