I'm looking into encoding in X265, but WMP won't play X265 files. I've read that the K-Lite codec will allow it. I currently play x264 files using the CCCP codec pack, which works very well. I'm concerned that installing the K-Lite will delete, or make un-usable the CCCP codecs. Does anyone know if K-Lite and CCCP can co-exists on the same PC(Win 7)?
Thanks!![]()
Results 1 to 15 of 15
One codec pack is bad enough, but you are going for 2
Odds are that you will develop issues -
For 32-bit decoding of H.265 video: use the Strongene Lentoid Decoder.
For 64-bit decoding of H.265 video: use LAV Video.
Cyberlink's "PDVD Generic" Video Decoder is another good alternative, IMHO.
Windows Media Player sucks anyway, so you'd better not use it at all.Last edited by El Heggunte; 16th Oct 2016 at 18:56. Reason: stupid typo
CCCP has switched from ffdshow to LAV long ago and already includes HEVC decoding. Also has a 64 bit version now.
I don't know whether CCCP works in WMP by default. Try (re-)installing latest CCCP and loading defaults. If it still doesn't work it might require https://www.videohelp.com/software/Preferred-Filter-Tweaker for it to be used in WMP. -
Thanks for all the responses. I'll have to research/try out those options.
Codec packs are usually source of many issues with codecs... follow https://forum.videohelp.com/threads/380898-Will-installing-K-Lite-override-CCCP-codecs?...=1#post2463077 and https://forum.videohelp.com/threads/380898-Will-installing-K-Lite-override-CCCP-codecs?...=1#post2463097
I am a bit confused. I have CCCP installed and I use PotPlayer for playing media files and I don't use WMP for anything.
I use MediaPlayerClassic when any media files fails to play and it works. It came with CCCP.
Shall I uninstall CCCP?Sword is no substitute for kitchen-knife.
Slow Video Playback After Installing K Lite Codec Pack
By bakonfreek in forum Software PlayingReplies: 7Last Post: 8th Jun 2016, 09:24 -
Any downsides to installing K-Lite Codec pack ?
By Digmen1 in forum Software PlayingReplies: 7Last Post: 11th May 2013, 15:42 -
Using PotPlayer with k-lite codecs pack
By Yaron in forum Newbie / General discussionsReplies: 8Last Post: 4th Oct 2012, 18:03 -
installing proprietary VfW codecs in Ubuntu
By mmatta in forum LinuxReplies: 1Last Post: 23rd Jul 2012, 00:20 -
Missing codecs after update of K Lite
By Zoro83 in forum Newbie / General discussionsReplies: 7Last Post: 9th Apr 2012, 11:46
