Alright, now theres been aheap of talk with fitting movies onto 1 CD etc, but its always been regarding TMPG Enc.. now my question is anyone got some guides to fit movies onto a single cd with CCE.
CCE is just so much faster for my machine, so was curious.
It all boils down to lowering the bitrate and/or adjusting quality settings. You can do that with any encoder.
CCE maybe best for a "ONE CD" application due to its multipass system. I suggest like 4 or 5 passes with CCE and just use a bitrate calc to figure out the bitrate.
Its not that big of a deal to change CDs during a movie. Look at LaserDisc for instance. Just use 2 cds .. the quality is worth the size and time.Mike of DHI Music Group
darklink.org -
way i look at it, fitting movies on one cd is fun for exploration, but if i'm going to take the time to encode it, i might as well go for the 2-3 cd approach.
but of course, there might be cases where 1 cd would be preferable.
if that's the case, i'd go with Kwag's template. works like a charm~Cheers~
JCPicache
Fitting more onto a DVD
By Woolen Llama in forum Authoring (DVD)Replies: 14Last Post: 23rd Sep 2010, 07:31 -
Fitting more in the dvd
By btkuehn in forum Newbie / General discussionsReplies: 2Last Post: 17th Nov 2008, 17:53 -
fitting four hours on 4.7 GB DVD
By cthiesen in forum Newbie / General discussionsReplies: 34Last Post: 13th Apr 2008, 17:36 -
Help Fitting Videos on CD...
By skinnerback in forum Video ConversionReplies: 4Last Post: 4th Sep 2007, 17:12 -
fitting more than 1 film on a dvd - help!
By welshgal in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2007, 13:16
