    Oct 2016
    Saudi Arabia
    Regards for everybody:
    Can anybody help; I have an extracted Blu-Ray file that contains both Director’s Cut and Theater Cut.
    How can I generate two movie files for each, please note that the overall files are several m2ts files with several portions and are not in sequential order?
    I remember in 3 years ago I used to use a software that will do this job but unluckily I forget that software “it seems I am getting old”
  2. MakeMKV should work. Run once and select the director's cut and then run a second time for the theater cut. Then you'll have two 1:1 copies as mkv. Compress afterwards if wanted with the software of your choice (e.g. HandBrake).
