I have always used Adobe Premiere 6.0 & I did try the newer versions. But the layouts suck & they seem to be more complicated. is there another program out there like Premiere but easy to use & can import all of the usual Video Formats & maybe even Direct Stream Export without re encoding ? Im just really looking for something that makes it easier to import & edit mp4s, mkvs without reencoding etc
XmediaRecode.
If you want a real editor that's free and similar to the old Premiere, switch to Linux and install Kdenlive.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........
Adobe After Effect Alternative Help
By JayManOurMusicBox in forum Newbie / General discussionsReplies: 6Last Post: 13th Dec 2015, 20:46 -
Adobe Premiere Alternative That Imports MKV & MP4
By TheRandomOne in forum EditingReplies: 14Last Post: 6th Sep 2015, 12:03 -
Nearest alternative to Adobe Encore?
By philglew in forum Authoring (DVD)Replies: 4Last Post: 19th May 2015, 15:45 -
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 22:43 -
Whats the alternative to Adobe After Effects ?
By AjnabiZ in forum EditingReplies: 15Last Post: 19th Oct 2011, 18:33
