I made a vcd of a movie that has subtitles. The problm is when i playu it on my tv the edges of the movie are cut off. Because opf this i cant see the subitiles. How can i make the vcd work with my tv size?
If you made it to VCD standard resolution, it is probably your tv or dvd player causing the problem. Some tvs have a control on them to adjust the video, look at your tv manuel for this. Or see dvd players have a feature that allows you to adjust the screen line up properties. Look at your DVD players man. for this.
I hope this helps. -
i found out what happened. I put the "pal" thing on (u pick pal or ntsf) I changed it to ntsf and it wokred.. ty for ur itme though
Strange video shift when set to big size
By peaceDOThuxDOTde in forum DVD RippingReplies: 1Last Post: 10th Jan 2012, 08:26 -
VideoReDo creates big blocks in video
By ChibiBoi in forum EditingReplies: 7Last Post: 18th Dec 2009, 18:34 -
.FLV for 10 minute video way too big
By Pureweb in forum Video Streaming DownloadingReplies: 48Last Post: 28th Mar 2009, 05:53 -
video file to big?
By just in forum Newbie / General discussionsReplies: 4Last Post: 21st Nov 2008, 00:34 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2008, 00:51
