I'm seeking a program with which to cut out all but a part of MKV video files.
Hopefully losslessly, visually (i.e. I can see where to cut), easy to learn/use, and *very* inexpensive since my budget is small.
Free programs with a preview would include avidemux , xmedia recode . They have to be set to "copy" as to not re-encode the video and/or audio . They are GOP accurate cutters (they cut only on keyframes, which might be a few frames off from where you want to cut precisely) .
Commercial programs that are frame accurate (and re-encode a few frames around a cutsite, if the cut isn't on an I-frame boundary) include videoredo, solveigmm video splitter, tmpg smart renderer -
Thank you very much for your great reply, poisondeathray!
I'm fine with one that isn't frame accurate.
An advantage of avidemux is that I have a bit of experience with it. Including that it wouldn't open some filetypes (IIRC mp4; I don't think I ever tried an MKV) sometimes. So good to hear you mention xmedia recode too.
Particularly because at $50 to $70, I really can't afford those Commercial programs. -
AviDemux is my go-to editor for MKV. Always on the look-out for good, free editors, I installed XMedia Recode and opened an HD MKV. Finally figured out that you need to click on the Filters/Preview tab to see video, but my 1080i video is a tiny box in the middle of the preview area. I tried sliding an unlabelled control all the way to the right, but no joy. I see there is a Resolution filter activated that says video size 128x96 but there is no way to remove it. Finally I change the format to Matroska and I now have 1080i video instead of a tiny box. Had to change both video and audio to copy instead of convert. Maybe the left and right arrow keys advance to the next key frame? Oh my, the help is in German, so hard to say without a translator. Now I see that Baldrick did a guide but it doesn't say how to advance to the next key frame, just says the cut won't be exact. Not good, I need to know exactly where I am cutting. Maybe the left and right arrow do that...
Best program for editing mpeg 4 mkv files.
By StumpedTechy in forum EditingReplies: 2Last Post: 28th Sep 2014, 03:32 -
How to cut mkv files WITH subs?
By shernoam in forum EditingReplies: 38Last Post: 14th Aug 2014, 15:37 -
Is there are program like MKV Merge for WMV files?
By KyleMadrid in forum Newbie / General discussionsReplies: 7Last Post: 17th May 2013, 22:17 -
Is there a program similar to TMPGEnc for .mp4 and .mkv files?
By Shinjikun in forum Newbie / General discussionsReplies: 5Last Post: 9th Sep 2012, 15:15 -
Re-numbering MKV files[program to do so]
By cal_tony in forum Video ConversionReplies: 7Last Post: 24th Jan 2012, 23:27
