Hi esteemed mates,
Because DVD Shrink would not rip my DVD, I installed and applied DVDfab which ripped the DVD into 3 large ISO files.
I then tried to burn a DVD of those ISO files all in the same folder using Ashampoo.
I get the message from AShampoo to insert a Double Layer DVD+ blank disc.
All I have are blank DVD-R single layer discs.
Is there some way or software which will take all the files ripped by dvdfab and burn them to a single layer DVD-R?
Thanks so much fr your help.
Results 31 to 38 of 38
Re rip the disc with dvdfab, once done, open dvd shrink
To shrink the file, once that is done hit backup and select iso
Once encoding is done just burn the iso to dvd -r using imgburn. -
Three iso files
Something is wrong
Should have got one
Rip the disc to a DVD folder not an ISO
It should be less than 8 gig
Anything larger than that means dFab is not decrypting correctly and you are getting false multiple copies
Which is one form of copy protection
In this case you need to use dFab to rip only the the main movie
Then author a new DVD with something like avi2dvd -
Hi october262,
Thanks for your suggestions.
I ripped the DVD using dvdfab which produced 7-8 large .VOB files and other smaller .VOB files on to my hard drive.
I did not then use dvdshrink as I thought I could then just burn a DVD with Ashampoo.
I can try your suggestions and shrink the file with dvdshrink and then once that's done hit backup and select iso.
Once the ISO file(s) are created by dvdshrink try to burn with ImgBurn which I've now downloaded.
Thank you again for all your help.
Hi thewizard,
Thank you for all the troubleshooting.
As an admitted newbie, I'm a tad lost at your suggestions of ..." Rip the disc to a DVD folder not an ISO."
How does one rip the disc to a DVD folder instead of an ISO?
Is there some setting in dvdfab for that?
There's actually three (3) separate programs on the original DVD, not just one movie.
My apologies if I wasn't clear about that originally.
Thank you for all your kind help.
Hi october,
Your suggestions worked perfectly!
Thank you so very much.
I wondered if you or others on this thread might have a favorite DVD label creation program for printing labels to blank DVDs?
Also, I noticed when i ran dvdfab it stated my trial version expired.
Is there a freeware version of dvdfab that I missed?
Thank you ALL for all your much appreciated brainstorming, suggestions and kind help.
<snip>
Once encoding is done just burn the iso to dvd -r using imgburn.[/QUOTE] -
I have a PhotoDirector 12 which stucks/freezes at 99% while analyzing a c
By avz10 in forum EditingReplies: 1Last Post: 11th Aug 2014, 10:37 -
[C#] Encoding stops
By Keller501 in forum ProgrammingReplies: 3Last Post: 1st Aug 2014, 09:04 -
Analyzing Multiple Video Files
By newpath in forum Newbie / General discussionsReplies: 2Last Post: 27th Dec 2013, 03:50 -
Chapter Stops
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 26th Oct 2013, 09:24 -
Need Help Analyzing Why .avi will not play on PS3
By kingaddi in forum Newbie / General discussionsReplies: 19Last Post: 24th Aug 2012, 10:56
