I am using a computer with a Visual Circuits, Inc. four channel Video Board to provide movies to a facility.
. It is recommended that I use videos with m2p format. Where can I get an encoder for this purpose?
George
m2p format video is just MPEG-2 so if you where to encode to .mpg then rename the file to .m2p the device should be able to see it
Thanks for your help. I will try it and find out. L will let you know the results.
George -
From what I've read M2P stands for MPEG 2 Program stream -- presumably the same as *.MPG, just with a different extension.
Which format is the best?
By harky in forum Video ConversionReplies: 9Last Post: 12th Jun 2016, 18:42 -
How to format C: ?
By Jomapil in forum ComputerReplies: 21Last Post: 25th Nov 2014, 10:07 -
has anyone tried FORMAT FACTORY
By hilario in forum Newbie / General discussionsReplies: 3Last Post: 29th May 2012, 15:42 -
what format
By agent222 in forum Video Streaming DownloadingReplies: 3Last Post: 15th Jan 2012, 14:34 -
what format is the best
By kent andersen in forum Newbie / General discussionsReplies: 6Last Post: 20th Dec 2011, 15:08
