Hello.
I have 2 m2ts files:
- one which has a corrupted video and subtitles.
- the second which has a good video but not the English subtitle.
So I used txmuxer to create a file which contains the subtitle from file A to the AV from file B.
and I chose to put it as BD folder.
When using BDinfo to check for the measured bitrate, it gives me the correct number.
I then copied the mux file with clipinfo file to the original BD folder and correct the name (overwrite the existing one).
Now using BDinfo on the original folder, the created/copied file now shows 0 measured bitrate, and while playing the section it never ends normally (it cuts at the last 3 seconds).
Any idea why this is happening? and how to correct it?
Thank you.
Results 1 to 1 of 1
Replacing multiple M2TS files with one large M2TS - possible??
By kpic in forum Authoring (Blu-ray)Replies: 0Last Post: 1st Nov 2014, 01:55 -
Burning M2TS files to BD-R
By hockeyman99 in forum Authoring (DVD)Replies: 5Last Post: 8th Jul 2014, 11:18 -
Want to change multiple m2ts files into mkv files
By jbitakis in forum Video ConversionReplies: 1Last Post: 10th Dec 2013, 03:41 -
Help with multiple .m2ts files to one .m2ts
By neworldman in forum Blu-ray RippingReplies: 10Last Post: 4th Sep 2013, 11:16 -
Mux several MKV files to several m2ts files
By jomoe in forum Video ConversionReplies: 2Last Post: 10th Feb 2012, 04:14
